Error with ./webodm.sh start --dev on windows
so i was trying to see how i can access the developer mode of webodm and i read through the readme.md file on the webodm repo.i was instructed to enter ./webodm.sh start --dev to enter the developer mode. I did it and was met with an error which was /bin/bash: /webodm/wait-for-postgres.sh: /bin/bash^M: bad interpreter: No such file or directory i opened the docker-compose.dev.yml file where i noticed the occurance of chmod being used. i realised that this is unix/linux only which is why i was getting an error on windows. now what do i do to be able to enter the development mode on windows?
Right, start-dev-env.sh is a convenience script for Linux. You might be able to modify it to get it to work on Windows, but it will not work on Windows as-is.
Open the script and look at the commands that are used to launch the environment.
The basic idea is to launch a ODM container, then mount a docker volume at /code (where the ODM code is inside the container) to a Windows directory containing your git checkout folder (the folder with your modifications). Then you need to re-run the bash configure.sh reinstall command so that the build and SuperBuild directory are populated properly in your git folder.
Careful with the git checkout process! Make sure to use:
git clone https://github.com/OpenDroneMap/ODM --config core.autocrlf=input
Otherwise git might convert line endings to and cause the issues you mentioned.
