From @florianbeyer on Fri Nov 17 2017 14:56:09 GMT+0000 (UTC)
I’m using docker to perform ODM.
sudo docker run -it --rm -v ~/Documents/ODM_projects/odm_tribsees/images:/code/images -v ~/Documents/ODM_projects/odm_tribsees/odm_orthophoto:/code/odm_orthophoto -v ~/Documents/ODM_projects/odm_tribsees/odm_texturing:/code/odm_texturing opendronemap/opendronemap
It takes a while and it seems that ODM is processing the data correctly.
During processing I got the following error:
Writing data cost file... done.
2746 faces have not been seen by a view.
Comp Iter Energy Runtime
0000 0 278335 0.008
0000 1 206246 0.665
0000 2 186136 1.307
0000 3 177782 1.949
0000 4 172069 2.606
0000 5 167856 3.263
0000 6 165498 3.922
0000 7 163897 4.57
0000 8 162838 5.215
0000 9 162258 5.913
0000 10 161384 6.566
0000 11 160591 7.219
0000 12 159872 7.868
0000 13 159027 8.524
0000 14 158662 9.175
0000 15 158049 9.829
0000 16 157522 10.481
0000 17 157276 11.126
0000 18 156889 11.772
0000 19 156584 12.418
0000 20 156372 13.076
0000 21 156045 13.733
0000 22 155968 14.385
0000 23 155587 15.034
0000 24 155439 15.68
0000 25 155385 16.334
0000 26 155107 16.978
0000 27 154959 17.624
0000 28 154687 18.266
0000 29 154484 18.91
0000 30 154478 19.565
0000 31 154373 20.226
0000 32 154288 20.936
0000 33 154166 21.588
0000 34 154119 22.244
0000 35 153995 22.893
0000 36 153987 23.535
0000 37 153906 24.192
0000 38 153851 24.845
0000 39 153819 25.496
0000 40 153642 26.14
0000 41 153552 26.785
0000 42 153572
0000 Increase of energy - stopping optimization
Took: 262.069s
Generating texture patches:
Running... done. (Took 378.718s)
368 texture patches.
Running global seam leveling:
Create matrices for optimization... done.
Lhs dimensionality: 105836 x 105836
Calculating adjustments:
Color channel 0: CG took 88 iterations. Residual is 9.02522e-05
Color channel 1: CG took 88 iterations. Residual is 9.62096e-05
Color channel 2: CG took 83 iterations. Residual is 9.27548e-05
Took 1.645 seconds
Adjusting texture patches 0%...Killed
File "/code/run.py", line 47, in <module>
plasm.execute(niter=1)
File "/code/scripts/mvstex.py", line 124, in process
'{keepUnseenFaces}'.format(**kwargs))
File "/code/opendm/system.py", line 34, in run
Exception: Child returned 137
Can someone help me?
What is the problem?
Copied from original issue: https://github.com/OpenDroneMap/OpenDroneMap/issues/714
