Error with --camera-lens brown parameter
I am trying to force ‘brown’ on a data set taken with Sony A7 which defaults to ‘perspective’. Feeding this parameter to the command line yields:
run.py: error: unrecognized arguments: --camera-lens
Documentation specifies this as a valid option.
Any ideas why this param was not accepted?
Tnx
I had this same issue as well. I think this was just recently rolled into master and I’m not sure which commit, but if you can update ODM and all its components, you should be able to use it.
Tnx @Saijin_Naib,
I am just using the standard docker command
docker run -ti --rm -v /my/project:/datasets/code opendronemap/odm --project-path /datasets
How do I know which version am I using?
Update your docker image…
Just tried
docker pull opendronemap/opendronemap
from here: https://hub.docker.com/r/opendronemap/opendronemap
and the result was:
user@user-dell5400:~$ docker pull opendronemap/opendronemap
Using default tag: latest
Error response from daemon: manifest for opendronemap/opendronemap:latest not found: manifest unknown: manifest unknown
Is this the wrong way to update?
Try docker pull opendronemap/odm.
worked. Kudos.
