Error when trying to create a new model
HTTPConnectionPool(host=‘webodm-node-odm-1’, port=3000): Max retries exceeded with url: /info (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0xffff970d0340>: Failed to establish a new connection: [Errno -2] Name or service not known’))
the above is in dashboard
Sorry for the trouble! Could you please start with giving me a bit more information about your system?
For instance:
  1. Operating System and Version
    eg: Windows 11, MacOS 15.1, Ubuntu Linux 20.04LTS, etc…
  2. WebODM Install Method
  3. WebODM/ODM Version
    eg: WebODM v1.9.12 Build 55, ODM v2.8.0, etc…
  4. Procesing Node
    eg: Automatic, Lightning, local (node-odm-1), etc…
  5. Screenshots demonstrating the issue/behavior/error messages
I vaguely recall encountering this error before and it was because NodeODM wasn’t running. “Name or service not known” suggests there is no process listening on localhost port 3000.
  1. m1 mac monterey 12.3 (21E230)
  2. native install
  3. 1.3 webodm
  4. local(node-odm-1)
okay i believe it was an error due to docker i deleted and reinstalled docker and its working now thanks.
Excellent! Happy processing!
Please show us what you’re working on in #the-showroom if you’d like!
Here the same ( WebODM 1.9.13) … but reinstall the docker doesn’t fix the problem …
Connection error: HTTPConnectionPool(host=‘webodm-node-odm-1’, port=3000): Max retries exceeded with url: /info (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0xffff618e9ee0>: Failed to establish a new connection: [Errno -2] Name or service not known’))
Managed it myself. at processing-node there were two node-odm (for whatever reason). I deleted the inactive one. now it works
