Error running webodm.sh in NixOS
I amended the shebang in the webodm.sh file to: #!/usr/bin/env bash
The script executed with the following errors. Please advise !!! Thank you:
[[email protected]:~]$ cd WebODM
[[email protected]:~/WebODM]$ ./webodm.sh start
Checking for docker… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-odm=1
File “/nix/store/cjhimawmks6yiiw4mdfhk60vhiym3536-python3.8-urllib3-1.26.4/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 699, in urlopen
httplib_response = self._make_request(
File “/nix/store/cjhimawmks6yiiw4mdfhk60vhiym3536-python3.8-urllib3-1.26.4/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/nix/store/32q6ryrb860sksdi1al5djg3pgcpq92l-python3-3.8.11/lib/python3.8/http/client.py”, line 1256, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/nix/store/32q6ryrb860sksdi1al5djg3pgcpq92l-python3-3.8.11/lib/python3.8/http/client.py”, line 1302, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/nix/store/32q6ryrb860sksdi1al5djg3pgcpq92l-python3-3.8.11/lib/python3.8/http/client.py”, line 1251, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/nix/store/32q6ryrb860sksdi1al5djg3pgcpq92l-python3-3.8.11/lib/python3.8/http/client.py”, line 1011, in _send_output
self.send(msg)
File “/nix/store/32q6ryrb860sksdi1al5djg3pgcpq92l-python3-3.8.11/lib/python3.8/http/client.py”, line 951, in send
self.connect()
File “/nix/store/1xdc10gdh8gzi9vy120a71hql5ky8ixk-python3.8-docker-4.4.4/lib/python3.8/site-packages/docker/transport/unixconn.py”, line 43, in connect
sock.connect(self.unix_socket)
FileNotFoundError: [Errno 2] No such file or directory
File “/nix/store/h4x196l4p1fd4nbd6vkz0fkgvz0lq210-python3.8-requests-2.25.1/lib/python3.8/site-packages/requests/adapters.py”, line 439, in send
resp = conn.urlopen(
File “/nix/store/cjhimawmks6yiiw4mdfhk60vhiym3536-python3.8-urllib3-1.26.4/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 755, in urlopen
retries = retries.increment(
File “/nix/store/cjhimawmks6yiiw4mdfhk60vhiym3536-python3.8-urllib3-1.26.4/lib/python3.8/site-packages/urllib3/util/retry.py”, line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/nix/store/cjhimawmks6yiiw4mdfhk60vhiym3536-python3.8-urllib3-1.26.4/lib/python3.8/site-packages/urllib3/packages/six.py”, line 734, in reraise
raise value.with_traceback(tb)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
File “/nix/store/1xdc10gdh8gzi9vy120a71hql5ky8ixk-python3.8-docker-4.4.4/lib/python3.8/site-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/nix/store/1xdc10gdh8gzi9vy120a71hql5ky8ixk-python3.8-docker-4.4.4/lib/python3.8/site-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/nix/store/1xdc10gdh8gzi9vy120a71hql5ky8ixk-python3.8-docker-4.4.4/lib/python3.8/site-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/nix/store/1xdc10gdh8gzi9vy120a71hql5ky8ixk-python3.8-docker-4.4.4/lib/python3.8/site-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/nix/store/h4x196l4p1fd4nbd6vkz0fkgvz0lq210-python3.8-requests-2.25.1/lib/python3.8/site-packages/requests/sessions.py”, line 555, in get
return self.request(‘GET’, url, **kwargs)
File “/nix/store/h4x196l4p1fd4nbd6vkz0fkgvz0lq210-python3.8-requests-2.25.1/lib/python3.8/site-packages/requests/sessions.py”, line 542, in request
resp = self.send(prep, **send_kwargs)
File “/nix/store/h4x196l4p1fd4nbd6vkz0fkgvz0lq210-python3.8-requests-2.25.1/lib/python3.8/site-packages/requests/sessions.py”, line 655, in send
r = adapter.send(request, **kwargs)
File “/nix/store/h4x196l4p1fd4nbd6vkz0fkgvz0lq210-python3.8-requests-2.25.1/lib/python3.8/site-packages/requests/adapters.py”, line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
File “/nix/store/7i7ggchqdxv862jf32gigwrax1vkcksc-docker-compose-1.28.6/bin/.docker-compose-wrapped”, line 9, in
sys.exit(main())
File “/nix/store/7i7ggchqdxv862jf32gigwrax1vkcksc-docker-compose-1.28.6/lib/python3.8/site-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/nix/store/7i7ggchqdxv862jf32gigwrax1vkcksc-docker-compose-1.28.6/lib/python3.8/site-packages/compose/cli/main.py”, line 198, in perform_command
project = project_from_options(’.’, options)
File “/nix/store/7i7ggchqdxv862jf32gigwrax1vkcksc-docker-compose-1.28.6/lib/python3.8/site-packages/compose/cli/command.py”, line 60, in project_from_options
return get_project(
File “/nix/store/7i7ggchqdxv862jf32gigwrax1vkcksc-docker-compose-1.28.6/lib/python3.8/site-packages/compose/cli/command.py”, line 152, in get_project
client = get_client(
File “/nix/store/7i7ggchqdxv862jf32gigwrax1vkcksc-docker-compose-1.28.6/lib/python3.8/site-packages/compose/cli/docker_client.py”, line 41, in get_client
client = docker_client(
File “/nix/store/7i7ggchqdxv862jf32gigwrax1vkcksc-docker-compose-1.28.6/lib/python3.8/site-packages/compose/cli/docker_client.py”, line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File “/nix/store/1xdc10gdh8gzi9vy120a71hql5ky8ixk-python3.8-docker-4.4.4/lib/python3.8/site-packages/docker/api/client.py”, line 197, in init
self._version = self._retrieve_server_version()
File “/nix/store/1xdc10gdh8gzi9vy120a71hql5ky8ixk-python3.8-docker-4.4.4/lib/python3.8/site-packages/docker/api/client.py”, line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
Sorry for the trouble.
Does your OS have a more recent Python? Maybe 3.9?
Yes, python 3.9 is available - should i be using 3.9?
Yes, try that and make sure that any other system-installed dependencies are fully up to date as well.
Something like topgrade can take care of this easily for you.
I installed python 3.9.4 … $python --version >>> Python 3.9.4
Restarted machine.
Same error as above :frowning:
Can you ensure that Docker is running and that your user is in the Docker group?
