I’ll just post the error 1 list that happens every time I try to calculate a orthopoto. With 1 image or 200. Tried with multiple configurations and is always the same. I’m with Docker and macOS.
[INFO] Initializing OpenDroneMap app - Mon Mar 16 18:54:34 2020
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 2.0
[INFO] depthmap_resolution: 1000.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] ignore_gsd: True
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 10
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] mve_confidence: 0.6
[INFO] name: 2c6dff43-a707-4f3d-a81d-09ac4803ade7
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 2.0
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/2c6dff43-a707-4f3d-a81d-09ac4803ade7/images
[INFO] Loading 202 images
[INFO] Wrote images database: /var/www/data/2c6dff43-a707-4f3d-a81d-09ac4803ade7/images.json
[INFO] Found 202 usable images
[INFO] Parsing SRS header: WGS84 UTM 29N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] [‘use_exif_size: no’, ‘feature_process_size: 2048’, ‘feature_min_frames: 8000’, ‘processes: 8’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘depthmap_method: PATCH_MATCH’, ‘depthmap_resolution: 1000.0’, ‘depthmap_min_patch_sd: 1’, ‘depthmap_min_consistent_views: 3’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘bundle_common_position_constraints: no’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running /usr/bin/env python2 /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata “/var/www/data/2c6dff43-a707-4f3d-a81d-09ac4803ade7/opensfm”
2020-03-16 18:54:36,514 INFO: Extracting EXIF for DJI_0705.JPG
2020-03-16 18:54:36,520 INFO: Extracting EXIF for DJI_0741.JPG
2020-03-16 18:54:36,525 INFO: Extracting EXIF for DJI_0321.JPG
2020-03-16 18:54:36,532 INFO: Extracting EXIF for DJI_0692.JPG
2020-03-16 18:54:36,538 INFO: Extracting EXIF for DJI_0717.JPG
2020-03-16 18:54:36,543 INFO: Extracting EXIF for DJI_0755.JPG
2020-03-16 18:54:36,548 INFO: Extracting EXIF for DJI_0697.JPG
2020-03-16 18:54:36,553 INFO: Extracting EXIF for DJI_0285.JPG
2020-03-16 18:54:36,560 INFO: Extracting EXIF for DJI_0265.JPG
2020-03-16 18:54:36,568 INFO: Extracting EXIF for DJI_0764.JPG
2020-03-16 18:54:36,574 INFO: Extracting EXIF for DJI_0244.JPG
2020-03-16 18:54:36,582 INFO: Extracting EXIF for DJI_0744.JPG
2020-03-16 18:54:36,587 INFO: Extracting EXIF for DJI_0237.JPG
2020-03-16 18:54:36,596 INFO: Extracting EXIF for DJI_0694.JPG
2020-03-16 18:54:36,601 INFO: Extracting EXIF for DJI_0703.JPG
2020-03-16 18:54:36,607 INFO: Extracting EXIF for DJI_0261.JPG
2020-03-16 18:54:36,615 INFO: Extracting EXIF for DJI_0342.JPG
2020-03-16 18:54:36,620 INFO: Extracting EXIF for DJI_0691.JPG
2020-03-16 18:54:36,625 INFO: Extracting EXIF for DJI_0239.JPG
2020-03-16 18:54:36,633 INFO: Extracting EXIF for DJI_0715.JPG
2020-03-16 18:54:36,639 INFO: Extracting EXIF for DJI_0306.JPG
2020-03-16 18:54:36,646 INFO: Extracting EXIF for DJI_0718.JPG
2020-03-16 18:54:36,651 INFO: Extracting EXIF for DJI_0293.JPG
2020-03-16 18:54:36,659 INFO: Extracting EXIF for DJI_0688.JPG
2020-03-16 18:54:36,664 INFO: Extracting EXIF for DJI_0243.JPG
2020-03-16 18:54:36,672 INFO: Extracting EXIF for DJI_0276.JPG
2020-03-16 18:54:36,680 INFO: Extracting EXIF for DJI_0320.JPG
2020-03-16 18:54:36,685 INFO: Extracting EXIF for DJI_0279.JPG
2020-03-16 18:54:36,693 INFO: Extracting EXIF for DJI_0689.JPG
2020-03-16 18:54:36,698 INFO: Extracting EXIF for DJI_0223.JPG
2020-03-16 18:54:36,703 INFO: Extracting EXIF for DJI_0338.JPG
2020-03-16 18:54:36,708 INFO: Extracting EXIF for DJI_0763.JPG
2020-03-16 18:54:36,716 INFO: Extracting EXIF for DJI_0739.JPG
2020-03-16 18:54:36,723 INFO: Extracting EXIF for DJI_0222.JPG
2020-03-16 18:54:36,731 INFO: Extracting EXIF for DJI_0262.JPG
2020-03-16 18:54:36,741 INFO: Extracting EXIF for DJI_0295.JPG
2020-03-16 18:54:36,751 INFO: Extracting EXIF for DJI_0725.JPG
2020-03-16 18:54:36,758 INFO: Extracting EXIF for DJI_0225.JPG
2020-03-16 18:54:36,765 INFO: Extracting EXIF for DJI_0729.JPG
2020-03-16 18:54:36,772 INFO: Extracting EXIF for DJI_0267.JPG
2020-03-16 18:54:36,780 INFO: Extracting EXIF for DJI_0253.JPG
2020-03-16 18:54:36,788 INFO: Extracting EXIF for DJI_0337.JPG
2020-03-16 18:54:36,793 INFO: Extracting EXIF for DJI_0268.JPG
2020-03-16 18:54:36,801 INFO: Extracting EXIF for DJI_0699.JPG
2020-03-16 18:54:36,806 INFO: Extracting EXIF for DJI_0259.JPG
2020-03-16 18:54:36,814 INFO: Extracting EXIF for DJI_0706.JPG
2020-03-16 18:54:36,819 INFO: Extracting EXIF for DJI_0318.JPG
2020-03-16 18:54:36,824 INFO: Extracting EXIF for DJI_0340.JPG
2020-03-16 18:54:36,829 INFO: Extracting EXIF for DJI_0297.JPG
2020-03-16 18:54:36,837 INFO: Extracting EXIF for DJI_0315.JPG
2020-03-16 18:54:36,842 INFO: Extracting EXIF for DJI_0734.JPG
2020-03-16 18:54:36,847 INFO: Extracting EXIF for DJI_0246.JPG
2020-03-16 18:54:36,856 INFO: Extracting EXIF for DJI_0313.JPG
2020-03-16 18:54:36,861 INFO: Extracting EXIF for DJI_0710.JPG
2020-03-16 18:54:36,865 INFO: Extracting EXIF for DJI_0270.JPG
2020-03-16 18:54:36,873 INFO: Extracting EXIF for DJI_0716.JPG
2020-03-16 18:54:36,878 INFO: Extracting EXIF for DJI_0333.JPG
2020-03-16 18:54:36,884 INFO: Extracting EXIF for DJI_0329.JPG
2020-03-16 18:54:36,889 INFO: Extracting EXIF for DJI_0274.JPG
2020-03-16 18:54:36,898 INFO: Extracting EXIF for DJI_0283.JPG
2020-03-16 18:54:36,906 INFO: Extracting EXIF for DJI_0248.JPG
2020-03-16 18:54:36,914 INFO: Extracting EXIF for DJI_0713.JPG
2020-03-16 18:54:36,920 INFO: Extracting EXIF for DJI_0290.JPG
2020-03-16 18:54:36,927 INFO: Extracting EXIF for DJI_0234.JPG
2020-03-16 18:54:36,934 INFO: Extracting EXIF for DJI_0701.JPG
2020-03-16 18:54:36,939 INFO: Extracting EXIF for DJI_0696.JPG
2020-03-16 18:54:36,944 INFO: Extracting EXIF for DJI_0264.JPG
2020-03-16 18:54:36,951 INFO: Extracting EXIF for DJI_0308.JPG
2020-03-16 18:54:36,958 INFO: Extracting EXIF for DJI_0747.JPG
2020-03-16 18:54:36,963 INFO: Extracting EXIF for DJI_0323.JPG
2020-03-16 18:54:36,968 INFO: Extracting EXIF for DJI_0233.JPG
2020-03-16 18:54:36,974 INFO: Extracting EXIF for DJI_0232.JPG
2020-03-16 18:54:36,979 INFO: Extracting EXIF for DJI_0258.JPG
2020-03-16 18:54:36,988 INFO: Extracting EXIF for DJI_0738.JPG
2020-03-16 18:54:36,993 INFO: Extracting EXIF for DJI_0257.JPG
2020-03-16 18:54:37,001 INFO: Extracting EXIF for DJI_0728.JPG
2020-03-16 18:54:37,007 INFO: Extracting EXIF for DJI_0307.JPG
2020-03-16 18:54:37,014 INFO: Extracting EXIF for DJI_0229.JPG
2020-03-16 18:54:37,020 INFO: Extracting EXIF for DJI_0749.JPG
2020-03-16 18:54:37,024 INFO: Extracting EXIF for DJI_0311.JPG
2020-03-16 18:54:37,032 INFO: Extracting EXIF for DJI_0732.JPG
2020-03-16 18:54:37,037 INFO: Extracting EXIF for DJI_0303.JPG
2020-03-16 18:54:37,045 INFO: Extracting EXIF for DJI_0695.JPG
2020-03-16 18:54:37,050 INFO: Extracting EXIF for DJI_0730.JPG
2020-03-16 18:54:37,055 INFO: Extracting EXIF for DJI_0252.JPG
2020-03-16 18:54:37,063 INFO: Extracting EXIF for DJI_0719.JPG
2020-03-16 18:54:37,068 INFO: Extracting EXIF for DJI_0708.JPG
2020-03-16 18:54:37,072 INFO: Extracting EXIF for DJI_0336.JPG
2020-03-16 18:54:37,077 INFO: Extracting EXIF for DJI_0762.JPG
2020-03-16 18:54:37,082 INFO: Extracting EXIF for DJI_0702.JPG
2020-03-16 18:54:37,087 INFO: Extracting EXIF for DJI_0278.JPG
2020-03-16 18:54:37,095 INFO: Extracting EXIF for DJI_0743.JPG
2020-03-16 18:54:37,099 INFO: Extracting EXIF for DJI_0316.JPG
2020-03-16 18:54:37,104 INFO: Extracting EXIF for DJI_0221.JPG
2020-03-16 18:54:37,111 INFO: Extracting EXIF for DJI_0288.JPG
2020-03-16 18:54:37,120 INFO: Extracting EXIF for DJI_0272.JPG
2020-03-16 18:54:37,127 INFO: Extracting EXIF for DJI_0742.JPG
2020-03-16 18:54:37,132 INFO: Extracting EXIF for DJI_0335.JPG
2020-03-16 18:54:37,138 INFO: Extracting EXIF for DJI_0271.JPG
2020-03-16 18:54:37,145 INFO: Extracting EXIF for DJI_0281.JPG
2020-03-16 18:54:37,153 INFO: Extracting EXIF for DJI_0282.JPG
2020-03-16 18:54:37,161 INFO: Extracting EXIF for DJI_0704.JPG
2020-03-16 18:54:37,165 INFO: Extracting EXIF for DJI_0250.JPG
2020-03-16 18:54:37,173 INFO: Extracting EXIF for DJI_0693.JPG
2020-03-16 18:54:37,178 INFO: Extracting EXIF for DJI_0766.JPG
2020-03-16 18:54:37,182 INFO: Extracting EXIF for DJI_0302.JPG
2020-03-16 18:54:37,190 INFO: Extracting EXIF for DJI_0341.JPG
2020-03-16 18:54:37,196 INFO: Extracting EXIF for DJI_0228.JPG
2020-03-16 18:54:37,201 INFO: Extracting EXIF for DJI_0294.JPG
2020-03-16 18:54:37,209 INFO: Extracting EXIF for DJI_0334.JPG
2020-03-16 18:54:37,214 INFO: Extracting EXIF for DJI_0757.JPG
2020-03-16 18:54:37,219 INFO: Extracting EXIF for DJI_0722.JPG
2020-03-16 18:54:37,224 INFO: Extracting EXIF for DJI_0301.JPG
2020-03-16 18:54:37,232 INFO: Extracting EXIF for DJI_0227.JPG
2020-03-16 18:54:37,237 INFO: Extracting EXIF for DJI_0312.JPG
2020-03-16 18:54:37,244 INFO: Extracting EXIF for DJI_0300.JPG
2020-03-16 18:54:37,251 INFO: Extracting EXIF for DJI_0266.JPG
2020-03-16 18:54:37,259 INFO: Extracting EXIF for DJI_0280.JPG
2020-03-16 18:54:37,267 INFO: Extracting EXIF for DJI_0737.JPG
2020-03-16 18:54:37,273 INFO: Extracting EXIF for DJI_0255.JPG
2020-03-16 18:54:37,281 INFO: Extracting EXIF for DJI_0251.JPG
2020-03-16 18:54:37,288 INFO: Extracting EXIF for DJI_0254.JPG
2020-03-16 18:54:37,295 INFO: Extracting EXIF for DJI_0317.JPG
2020-03-16 18:54:37,303 INFO: Extracting EXIF for DJI_0226.JPG
2020-03-16 18:54:37,308 INFO: Extracting EXIF for DJI_0740.JPG
2020-03-16 18:54:37,313 INFO: Extracting EXIF for DJI_0735.JPG
2020-03-16 18:54:37,317 INFO: Extracting EXIF for DJI_0256.JPG
2020-03-16 18:54:37,326 INFO: Extracting EXIF for DJI_0310.JPG
2020-03-16 18:54:37,334 INFO: Extracting EXIF for DJI_0720.JPG
2020-03-16 18:54:37,339 INFO: Extracting EXIF for DJI_0236.JPG
2020-03-16 18:54:37,344 INFO: Extracting EXIF for DJI_0314.JPG
2020-03-16 18:54:37,352 INFO: Extracting EXIF for DJI_0284.JPG
2020-03-16 18:54:37,360 INFO: Extracting EXIF for DJI_0287.JPG
2020-03-16 18:54:37,367 INFO: Extracting EXIF for DJI_0224.JPG
2020-03-16 18:54:37,373 INFO: Extracting EXIF for DJI_0726.JPG
2020-03-16 18:54:37,377 INFO: Extracting EXIF for DJI_0709.JPG
2020-03-16 18:54:37,382 INFO: Extracting EXIF for DJI_0235.JPG
2020-03-16 18:54:37,387 INFO: Extracting EXIF for DJI_0231.JPG
2020-03-16 18:54:37,392 INFO: Extracting EXIF for DJI_0289.JPG
2020-03-16 18:54:37,400 INFO: Extracting EXIF for DJI_0298.JPG
2020-03-16 18:54:37,408 INFO: Extracting EXIF for DJI_0746.JPG
2020-03-16 18:54:37,414 INFO: Extracting EXIF for DJI_0291.JPG
2020-03-16 18:54:37,422 INFO: Extracting EXIF for DJI_0745.JPG
2020-03-16 18:54:37,427 INFO: Extracting EXIF for DJI_0324.JPG
2020-03-16 18:54:37,435 INFO: Extracting EXIF for DJI_0698.JPG
2020-03-16 18:54:37,440 INFO: Extracting EXIF for DJI_0304.JPG
2020-03-16 18:54:37,448 INFO: Extracting EXIF for DJI_0325.JPG
2020-03-16 18:54:37,454 INFO: Extracting EXIF for DJI_0241.JPG
2020-03-16 18:54:37,459 INFO: Extracting EXIF for DJI_0331.JPG
2020-03-16 18:54:37,467 INFO: Extracting EXIF for DJI_0752.JPG
2020-03-16 18:54:37,473 INFO: Extracting EXIF for DJI_0727.JPG
2020-03-16 18:54:37,478 INFO: Extracting EXIF for DJI_0296.JPG
2020-03-16 18:54:37,488 INFO: Extracting EXIF for DJI_0751.JPG
2020-03-16 18:54:37,493 INFO: Extracting EXIF for DJI_0711.JPG
2020-03-16 18:54:37,498 INFO: Extracting EXIF for DJI_0339.JPG
2020-03-16 18:54:37,506 INFO: Extracting EXIF for DJI_0765.JPG
2020-03-16 18:54:37,512 INFO: Extracting EXIF for DJI_0748.JPG
2020-03-16 18:54:37,517 INFO: Extracting EXIF for DJI_0275.JPG
2020-03-16 18:54:37,525 INFO: Extracting EXIF for DJI_0733.JPG
2020-03-16 18:54:37,530 INFO: Extracting EXIF for DJI_0260.JPG
2020-03-16 18:54:37,537 INFO: Extracting EXIF for DJI_0760.JPG
2020-03-16 18:54:37,542 INFO: Extracting EXIF for DJI_0756.JPG
2020-03-16 18:54:37,548 INFO: Extracting EXIF for DJI_0273.JPG
2020-03-16 18:54:37,556 INFO: Extracting EXIF for DJI_0712.JPG
2020-03-16 18:54:37,560 INFO: Extracting EXIF for DJI_0240.JPG
2020-03-16 18:54:37,565 INFO: Extracting EXIF for DJI_0754.JPG
2020-03-16 18:54:37,570 INFO: Extracting EXIF for DJI_0721.JPG
2020-03-16 18:54:37,575 INFO: Extracting EXIF for DJI_0759.JPG
2020-03-16 18:54:37,580 INFO: Extracting EXIF for DJI_0700.JPG
2020-03-16 18:54:37,585 INFO: Extracting EXIF for DJI_0322.JPG
2020-03-16 18:54:37,593 INFO: Extracting EXIF for DJI_0724.JPG
2020-03-16 18:54:37,598 INFO: Extracting EXIF for DJI_0761.JPG
2020-03-16 18:54:37,603 INFO: Extracting EXIF for DJI_0327.JPG
2020-03-16 18:54:37,610 INFO: Extracting EXIF for DJI_0277.JPG
2020-03-16 18:54:37,617 INFO: Extracting EXIF for DJI_0731.JPG
2020-03-16 18:54:37,623 INFO: Extracting EXIF for DJI_0736.JPG
2020-03-16 18:54:37,627 INFO: Extracting EXIF for DJI_0330.JPG
2020-03-16 18:54:37,635 INFO: Extracting EXIF for DJI_0714.JPG
2020-03-16 18:54:37,641 INFO: Extracting EXIF for DJI_0238.JPG
2020-03-16 18:54:37,646 INFO: Extracting EXIF for DJI_0758.JPG
2020-03-16 18:54:37,651 INFO: Extracting EXIF for DJI_0286.JPG
2020-03-16 18:54:37,659 INFO: Extracting EXIF for DJI_0247.JPG
2020-03-16 18:54:37,664 INFO: Extracting EXIF for DJI_0292.JPG
2020-03-16 18:54:37,672 INFO: Extracting EXIF for DJI_0707.JPG
2020-03-16 18:54:37,677 INFO: Extracting EXIF for DJI_0690.JPG
2020-03-16 18:54:37,682 INFO: Extracting EXIF for DJI_0723.JPG
2020-03-16 18:54:37,687 INFO: Extracting EXIF for DJI_0230.JPG
2020-03-16 18:54:37,692 INFO: Extracting EXIF for DJI_0326.JPG
2020-03-16 18:54:37,699 INFO: Extracting EXIF for DJI_0242.JPG
2020-03-16 18:54:37,704 INFO: Extracting EXIF for DJI_0269.JPG
2020-03-16 18:54:37,709 INFO: Extracting EXIF for DJI_0319.JPG
2020-03-16 18:54:37,717 INFO: Extracting EXIF for DJI_0249.JPG
2020-03-16 18:54:37,722 INFO: Extracting EXIF for DJI_0263.JPG
2020-03-16 18:54:37,727 INFO: Extracting EXIF for DJI_0309.JPG
2020-03-16 18:54:37,735 INFO: Extracting EXIF for DJI_0767.JPG
2020-03-16 18:54:37,740 INFO: Extracting EXIF for DJI_0750.JPG
2020-03-16 18:54:37,745 INFO: Extracting EXIF for DJI_0328.JPG
2020-03-16 18:54:37,753 INFO: Extracting EXIF for DJI_0305.JPG
2020-03-16 18:54:37,760 INFO: Extracting EXIF for DJI_0753.JPG
2020-03-16 18:54:37,765 INFO: Extracting EXIF for DJI_0245.JPG
2020-03-16 18:54:37,770 INFO: Extracting EXIF for DJI_0332.JPG
[INFO] running /usr/bin/env python2 /code/SuperBuild/src/opensfm/bin/opensfm detect_features “/var/www/data/2c6dff43-a707-4f3d-a81d-09ac4803ade7/opensfm”
2020-03-16 18:54:38,933 INFO: Extracting ROOT_SIFT features for image DJI_0299.JPG
2020-03-16 18:54:39,011 DEBUG: Computing sift with threshold 0.1
2020-03-16 18:54:39,209 INFO: Extracting ROOT_SIFT features for image DJI_0705.JPG
2020-03-16 18:54:39,286 DEBUG: Computing sift with threshold 0.1
2020-03-16 18:54:39,676 DEBUG: Found 16959 points in 0.665132045746s
2020-03-16 18:54:39,682 DEBUG: done
2020-03-16 18:54:39,731 INFO: Extracting ROOT_SIFT features for image DJI_0741.JPG
2020-03-16 18:54:39,825 DEBUG: Computing sift with threshold 0.1
2020-03-16 18:54:40,136 DEBUG: Found 8869 points in 0.849995851517s
2020-03-16 18:54:40,145 DEBUG: done
2020-03-16 18:54:41,555 DEBUG: Found 12332 points in 1.72932505608s
2020-03-16 18:54:41,573 DEBUG: done
2020-03-16 18:54:41,823 DEBUG: No segmentation for DJI_0299.JPG, no features masked.
2020-03-16 18:54:41,991 INFO: Extracting ROOT_SIFT features for image DJI_0321.JPG
2020-03-16 18:54:43,078 DEBUG: Computing sift with threshold 0.1
2020-03-16 18:54:43,139 DEBUG: No segmentation for DJI_0741.JPG, no features masked.
2020-03-16 18:54:43,317 DEBUG: No segmentation for DJI_0705.JPG, no features masked.
2020-03-16 18:54:43,804 DEBUG: Found 27528 points in 0.725902080536s
2020-03-16 18:54:43,805 DEBUG: done
2020-03-16 18:54:44,043 INFO: Extracting ROOT_SIFT features for image DJI_0692.JPG
2020-03-16 18:54:44,126 DEBUG: Computing sift with threshold 0.1
2020-03-16 18:54:44,858 DEBUG: No segmentation for DJI_0321.JPG, no features masked.
2020-03-16 18:54:44,948 DEBUG: Found 11496 points in 0.821572780609s
2020-03-16 18:54:44,948 DEBUG: done
2020-03-16 18:54:45,471 INFO: Extracting ROOT_SIFT features for image DJI_0717.JPG
2020-03-16 18:54:45,638 DEBUG: Computing sift with threshold 0.1
2020-03-16 18:54:45,810 DEBUG: No segmentation for DJI_0692.JPG, no features masked.
2020-03-16 18:54:46,292 INFO: Extracting ROOT_SIFT features for image DJI_0755.JPG
2020-03-16 18:54:46,378 DEBUG: Computing sift with threshold 0.1
2020-03-16 18:54:46,387 DEBUG: Found 13704 points in 0.748600006104s
2020-03-16 18:54:46,388 DEBUG: done
2020-03-16 18:54:47,521 ERROR: exception calling callback for <Future at 0x7f4e14779110 state=finished raised TerminatedWorkerError>
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/_base.py”, line 625, in _invoke_callbacks
callback(self)
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 309, in call
self.parallel.dispatch_next()
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 731, in dispatch_next
if not self.dispatch_one_batch(self._original_iterator):
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 759, in dispatch_one_batch
self._dispatch(tasks)
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 716, in _dispatch
job = self._backend.apply_async(batch, callback=cb)
File “/usr/local/lib/python2.7/dist-packages/joblib/_parallel_backends.py”, line 510, in apply_async
future = self._workers.submit(SafeFunction(func))
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/reusable_executor.py”, line 151, in submit
fn, *args, **kwargs)
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/process_executor.py”, line 1022, in submit
raise self._flags.broken
TerminatedWorkerError: A worker process managed by the executor was unexpectedly terminated. This could be caused by a segmentation fault while calling the function or by an excessive memory usage causing the Operating System to kill the worker. The exit codes of the workers are {SIGKILL(-9)}
File “/code/SuperBuild/src/opensfm/bin/opensfm”, line 34, in
command.run(args)
File “/code/SuperBuild/src/opensfm/opensfm/commands/detect_features.py”, line 31, in run
parallel_map(detect, arguments, processes, 1)
File “/code/SuperBuild/src/opensfm/opensfm/context.py”, line 41, in parallel_map
return Parallel(batch_size=batch_size)(delayed(func)(arg) for arg in args)
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 934, in call
self.retrieve()
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 833, in retrieve
File “/usr/local/lib/python2.7/dist-packages/joblib/_parallel_backends.py”, line 521, in wrap_future_result
return future.result(timeout=timeout)
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/_base.py”, line 433, in result
return self.__get_result()
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/_base.py”, line 381, in __get_result
raise self._exception
joblib.externals.loky.process_executor.
File “/code/run.py”, line 57, in
app.execute()
File “/code/opendm/types.py”, line 464, in run
File “/code/opendm/types.py”, line 445, in run
File “/code/stages/run_opensfm.py”, line 27, in process
File “/code/opendm/osfm.py”, line 204, in feature_matching
self.run(‘detect_features’)
File “/code/opendm/osfm.py”, line 22, in run
Exception: Child returned 1
