Error on Proj4 parameter (may be with GCP file and PROJ4 parameter)
I have received Error when process a 311 images fly.
I was prepare GCP file gcp_file_1561824115093.txt with this text:
+proj=tmerc +lat_0=-90 +lon_0=-69 +k=1 +x_0=2500000 +y_0=0 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
and I have seted PROJ4 parameter:
from here: https://spatialreference.org/ref/epsg/22182/proj4/
dtm parameter: true
dsm parameter: true
This was Error after uploaded the images:
[{“name”:“proj”,“error”:“Domain value cannot be handled: ‘PROJ4 string’ : '+proj=tmerc +lat_0=-90 +lon_0=-69 +k=1 +x_0=2500000 +y_0=0 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs '”}]
Could you help me?
You shouldn’t need to specify --proj. The GCP header should already take care of things.
