Error message
An error indication appeared on the console.
"ERROR: for webapp Can not start service webapp: driver failed programming external connectivity on endpoint webapp (81f42a7ffd80b7282929e7966a3e841983045c692aed153f04fa00b12767c692aed153f04fa00b12767c6a0): Error starting userland proxy: Bind for 0.0.0.0: 8000: unexpected error Permission denied
C: \ WebODM Manager \ WebODM> exit 1 "was found.
Please tell me the solution.
Typically pressing “Update” will resolve the problem. But there might be some other problem. The “Permission denied” suggests that perhaps you have some other service running on port 8000? If so, find which one it is and try disabling it.
From an elevated prompt you can find which one it is by running:
netstat -a -b
