Error installer
Good night dear colleagues I’m having difficulties installing the software could you guys help me?
at first I had an error with visual c++ redistributable packages for visual studio 2013 even when installing it, I did not recognize it as installed and requested the installation again.
So I uninstalled everything and started again.
and this second error appeared
“Booting WebODM 1.9.11 build 37…”
“Trying to connect to NodeODM localhost:29301…”
“Attempt 0 failed, retrying…”
“Attempt 1 failed, retrying…”
“Attempt 2 failed, retrying…”
“Attempt 3 failed, retrying…”
“Attempt 4 failed, retrying…”
“Attempt 5 failed, retrying…”
“nodeodm: error: Error during startup: Cannot read list of options from ODM (from temporary file). Is ODM installed in C:\WebODM\resources\app\apps\ODM?\r\n”
“nodeodm: exited with code 1”
“(node:2956) UnhandledPromiseRejectionWarning: Error: Exit code: 1\n at ChildProcess. (C:\WebODM\resources\app\utils.js:63:19)\n at ChildProcess.emit (events.js:210:5)\n at maybeClose (internal/child_process.js:1021:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)”
“(node:2956) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)”
“(node:2956) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.”
“Attempt 6 failed, retrying…”
“Attempt 7 failed, retrying…”
“Attempt 8 failed, retrying…”
“Attempt 9 failed, retrying…”
“Attempt 10 failed, retrying…”
“Attempt 11 failed, retrying…”
“Attempt 12 failed, retrying…”
“Attempt 13 failed, retrying…”
“Attempt 14 failed, retrying…”
Are you able to open C:\WebODM\resources\app\apps\ODM\console.bat? (It should show a long list of options).
yes, i can open it. a cosole appears with a list of options
Ok, if you open a command prompt and type:
C:\>cd c:\WebODM\resources\app\apps\NodeODM\
c:\WebODM\resources\app\apps\NodeODM>nodeodm.exe --odm_path c:\WebODM\resources\app\apps\ODM
info: Authentication using NoTokenRequired
info: Listening on 0.0.0.0:6367 UDP for progress updates
info: No tasks dump found
info: Checking for orphaned directories to be removed...
info: Server has started on port 3000
Do you get an error message?
