After several Orthomosaics created just fine, I’ve got this error…
plasm.execute(niter=1)
File “/code/scripts/odm_meshing.py”, line 108, in process
method=‘poisson’ if args.fast_orthophoto else ‘gridded’)
File “/code/opendm/mesh.py”, line 36, in create_25dmesh
max_workers=get_max_concurrency_for_dem(available_cores, inPointCloud)
File “/code/opendm/dem/commands.py”, line 34, in create_dems
fouts = list(e.map(create_dem_for_radius, radius))
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 794, in _chain_from_iterable_of_lists
for element in iterable:
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 589, in result_iterator
yield future.result()
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 433, in result
return self.__get_result()
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 381, in __get_result
raise self._exception
Exception: Child returned 1
This was caused directly by
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 418, in _process_worker
r = call_item()
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 272, in call
return self.fn(*self.args, **self.kwargs)
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 337, in _process_chunk
return [fn(*args) for args in chunk]
File “/code/opendm/dem/commands.py”, line 83, in create_dem
pdal.run_pipeline(json, verbose=verbose)
File “/code/opendm/dem/pdal.py”, line 163, in run_pipeline
out = system.run(’ ‘.join(cmd) + ’ > /dev/null 2>&1’)
File “/code/opendm/system.py”, line 34, in run
Anyone knows why ?
