Hi All,
I was processing images using ODM from native install… I am using the latest version pulled from github. I ran into this error at ODM_meshing stage:
e[94m[INFO] Running ODM Meshing Celle[0m
e[92m[DEBUG] Writing ODM Mesh file in: /datasets/code/odm_meshing/odm_mesh.plye[0m
e[92m[DEBUG] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /datasets/code/smvs/smvs_dense_point_cloud.ply --out /datasets/code/odm_meshing/odm_mesh.dirty.ply --depth 12 --pointWeight 0.0 --samplesPerNode 1.0 --threads 12 --linearFit e[0m
e[92m[DEBUG] running /code/build/bin/odm_cleanmesh -inputFile /datasets/code/odm_meshing/odm_mesh.dirty.ply -outputFile /datasets/code/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 1000000 e[0m
e[92m[DEBUG] Writing ODM 2.5D Mesh file in: /datasets/code/odm_meshing/odm_25dmesh.plye[0m
e[92m[DEBUG] ODM 2.5D DSM resolution: 0.1028e[0m
e[94m[INFO] Created temporary directory: /datasets/code/odm_meshing/tmpe[0m
e[94m[INFO] Creating DSM for 2.5D meshe[0m
e[94m[INFO] Creating ../datasets/code/odm_meshing/tmp/mesh_dsm_r0.145381154212 [max] from 1 filese[0m
e[92m[DEBUG] running pdal pipeline -i /tmp/tmpFIfj5V.json > /dev/null 2>&1e[0m
File "/code/run.py", line 47, in <module>
plasm.execute(niter=1)
File "/code/scripts/odm_meshing.py", line 108, in process
method='poisson' if args.fast_orthophoto else 'gridded')
File "/code/opendm/mesh.py", line 35, in create_25dmesh
max_workers=max_workers
File "/code/opendm/dem/commands.py", line 38, in create_dems
fouts = list(e.map(create_dem_for_radius, radius))
File "/usr/local/lib/python2.7/dist-packages/loky/process_executor.py", line 786, in _chain_from_iterable_of_lists
for element in iterable:
File "/usr/local/lib/python2.7/dist-packages/loky/_base.py", line 589, in result_iterator
yield future.result()
File "/usr/local/lib/python2.7/dist-packages/loky/_base.py", line 433, in result
return self.__get_result()
File "/usr/local/lib/python2.7/dist-packages/loky/_base.py", line 381, in __get_result
raise self._exception
Exception: Child returned 139
This was caused directly by
File "/usr/local/lib/python2.7/dist-packages/loky/process_executor.py", line 410, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python2.7/dist-packages/loky/process_executor.py", line 329, in _process_chunk
return [fn(*args) for args in chunk]
File "/code/opendm/dem/commands.py", line 92, in create_dem
pdal.run_pipeline(json, verbose=verbose)
File "/code/opendm/dem/pdal.py", line 232, in run_pipeline
out = system.run(' '.join(cmd) + ' > /dev/null 2>&1')
File "/code/opendm/system.py", line 34, in run
I also tried docker image(latest)…which gave the same error as above.
The command I gave was -
docker run -it --rm -v “/home/garlac/ODM_dev_version/ODMprojects/Docker_projects/MLA_3nov_v1:/datasets/code” opendronemap/opendronemap --mesh-point-weight 0 --force-ccd 12.8333 --texturing-nadir-weight 32 --smvs-output-scale 1 --ignore-gsd --orthophoto-resolution 2.57 --mesh-size 1000000 --time --mesh-octree-depth 12 --opensfm-depthmap-method “BRUTE_FORCE” --crop 0 --resize-to -1 --project-path ‘/datasets’
Earlier I didnt get such an error when --use-3dmesh
parameter was used!!
Is it a bug or some other problem.?
Thank you.
