Error elaborazione
hello, I get this error, what does it depend on? thank you
Sorry for the trouble!
This error sometimes happens when you’re uploading a lot of images to Lightning and your Internet connection can’t handle the outgoing bandwidth without trouble.
A few things you can try are to losslessly compress the images using something like Caesium Image Compressor:
Making sure your connection isn’t tethered via your phone, moving to a wired connection, or possibly seeing if you have a place nearby with a stronger connection.
hello, to process on the computer and not on Lightning or always have an internet connection? this error also gives it by not entering username and password in Lightning
You can choose where to process. When starting a new Task, you can choose your node as “node-odm-1”, which is local.
