The issue happen durring submodel opensfm processing step, in fused depthmap stage. Child returned 3221226505
Welcome! Sorry for the trouble.
Could you please provide the full processing log?
Are you able to copy and paste the full text from the console? It would be helpful.
Also, can you please confirm what version you’re using?
So sorry, i did note save to text the log from console.
The version of odm i’m using now is 2.6
Please upgrade to the current version and re-try your analysis with the same settings you used before:
Hello! thank you for your last suggestion.
update was done and i retried the processing, But there was the same error.
this is a copy past of the console :
2022-01-03 09:08:53,779 DEBUG: Undistorting image 010DJI0701.JPG
2022-01-03 09:08:53,871 DEBUG: Undistorting image 010DJI0457.JPG
2022-01-03 09:08:53,874 DEBUG: Undistorting image 010DJI0458.JPG
2022-01-03 09:08:53,889 DEBUG: Undistorting image 010DJI0459.JPG
2022-01-03 09:08:54,041 DEBUG: Undistorting image 030DJI0616.JPG
[INFO] running “C:\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” export_visualsfm --points “D:\Processing\code\submodels\submodel_0000\opensfm”
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[INFO] running “C:\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” export_openmvs “D:\Processing\code\submodels\submodel_0000\opensfm”
[INFO] Estimating depthmaps
[INFO] running “C:\ODM\SuperBuild\install\bin\OpenMVS\DensifyPointCloud” “D:\Processing\code\submodels\submodel_0000\opensfm\undistorted\openmvs\scene.mvs” --resolution-level 2 --min-resolution 500 --max-resolution 1712 --max-threads 12 --number-views-fuse 2 -w “D:\Processing\code\submodels\submodel_0000\opensfm\undistorted\openmvs\depthmaps” -v 0 --geometric-iters 0
12:40:53 [App ] Build date: Dec 24 2021, 00:39:57
12:40:53 [App ] CPU: Intel(R) Core™ i7-8700 CPU @ 3.20GHz (12 cores)
12:40:53 [App ] RAM: 47.82GB Physical Memory 128.00TB Virtual Memory
12:40:53 [App ] OS: Windows 8 x64
12:40:53 [App ] SSE & AVX compatible CPU & OS detected
12:40:53 [App ] Command line: D:\Processing\code\submodels\submodel_0000\opensfm\undistorted\openmvs\scene.mvs --resolution-level 2 --min-resolution 500 --max-resolution 1712 --max-threads 12 --number-views-fuse 2 -w D:\Processing\code\submodels\submodel_0000\opensfm\undistorted\openmvs\depthmaps -v 0 --geometric-iters 0
12:41:14 [App ] Preparing images for dense reconstruction completed: 2596 images (19s442ms)
12:41:41 [App ] Selecting images for dense reconstruction completed: 2596 images (26s790ms)
Estimated depth-maps 2596 (100%, 14m31s874ms)
Filtered depth-maps 2596 (100%, 9m48s721ms)
File “C:\ODM\stages\odm_app.py”, line 94, in execute
File “C:\ODM\opendm\types.py”, line 346, in run
File “C:\ODM\opendm\types.py”, line 327, in run
File “C:\ODM\stages\openmvs.py”, line 100, in process
raise e
File “C:\ODM\stages\openmvs.py”, line 91, in process
run_densify()
File “C:\ODM\stages\openmvs.py”, line 86, in run_densify
system.run(’"%s" “%s” %s’ % (context.omvs_densify_path,
File “C:\ODM\opendm\system.py”, line 106, in run
opendm.system.SubprocessException: Child returned 3221226505
[ERROR] The program exited with a strange error code. Please report it at https://community.opendronemap.org
[INFO] ========================
[INFO] Processing submodel_0001
[INFO] running “C:\ODM\run” --dtm --feature-quality medium --matcher-type bow --feature-type akaze --orthophoto-cutline --dem-euclidean-map --skip-3dmodel --skip-report --project-path “D:\Processing\code\submodels” submodel_0001
[INFO] Initializing ODM 2.7.0 - Mon Jan 03 13:09:53 2022
[INFO] auto_boundary: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: False
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_euclidean_map: True
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: True
[INFO] fast_orthophoto: False
[INFO] feature_quality: medium
[INFO] feature_type: akaze
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 8
[INFO] matcher_type: bow
[INFO] max_concurrency: 12
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: submodel_0001
[INFO] orthophoto_cutline: True
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: True
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] project_path: D:\Processing\code\submodels
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: True
[INFO] skip_orthophoto: False
[INFO] skip_report: True
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: D:\Processing\code\submodels\submodel_0001\images
[INFO] Loading 3761 images
[INFO] Wrote images database: D:\Processing\code\submodels\submodel_0001\images.json
[INFO] Found 3761 usable images
[INFO] Parsing SRS header: WGS84 UTM 38S
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[WARNING] D:\Processing\code\submodels\submodel_0001\opensfm\image_list.txt already exists, not rerunning OpenSfM setup
[WARNING] D:\Processing\code\submodels\submodel_0001\opensfm\exif already exists, not rerunning photo to metadata
[WARNING] Detect features already done: D:\Processing\code\submodels\submodel_0001\opensfm\features exists
[WARNING] Match features already done: D:\Processing\code\submodels\submodel_0001\opensfm\matches exists
[WARNING] Found a valid OpenSfM tracks file in: D:\Processing\code\submodels\submodel_0001\opensfm\tracks.csv
[WARNING] Found a valid OpenSfM reconstruction file in: D:\Processing\code\submodels\submodel_0001\opensfm\reconstruction.json
[INFO] running “C:\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” export_geocoords --reconstruction --proj “+proj=utm +zone=38 +south +datum=WGS84 +units=m +no_defs +type=crs” --offset-x 512705.0 --offset-y 8032620.0 “D:\Processing\code\submodels\submodel_0001\opensfm”
[INFO] Updating D:\Processing\code\submodels\submodel_0001\opensfm\config.yaml
[INFO] undistorted_image_max_size: 1418
[INFO] Undistorting D:\Processing\code\submodels\submodel_0001\opensfm …
2022-01-03 13:23:49,556 DEBUG: Undistorting image 1080DJI0319.JPG
2022-01-03 13:23:49,556 DEBUG: Undistorting image 3040DJI0173.JPG
2022-01-03 13:23:49,557 DEBUG: Undistorting image 1090DJI0408.JPG
2022-01-03 13:23:49,558 DEBUG: Undistorting image 200DJI_0296.JPG
2022-01-03 13:23:49,558 DEBUG: Undistorting image 3030DJI0152.JPG
2022-01-03 13:23:49,558 DEBUG: Undistorting image 2050DJI0018.JPG
2022-01-03 13:23:49,558 DEBUG: Undistorting image 3040DJI0339.JPG
2022-01-03 13:23:49,559 DEBUG: Undistorting image 2080DJI0073.JPG
2022-01-03 13:23:49,559 DEBUG: Undistorting image 2060DJI0934.JPG
2022-01-03 13:23:49,559 DEBUG: Undistorting image 3030DJI0400.JPG
2022-01-03 13:23:49,559 DEBUG: Undistorting image 2070DJI0456.JP
Are you able to share your dataset somewhere?
Also, is your Windows 8 machine fully up to date?
unfortunatly i can not share the dataset yet!
yes, I think the OS is up to date
So, might it be an issue from the OS?
Really hard to say without being able to see/use the data.
Can you use a different feature type? SIFT instead of AKAZE and re-test?
for precision the OS is an Windows 10 Pro
For the feature type option, i have already used Shift as feature type before, with the 2.6.7 version of the ODM, no sucess.
If i use docker ODM instead of Windows, will it change something?
It’s quite possible you might be running out of memory?
2596 images with 48GB of RAM is often not sufficient.
Have you tried with fewer images?
ohhh! I use 350 images with split 100 and split overlap 50 and it woks until new error went up
and this script is open automaticaly:
#!/usr/bin/env python3
import sys
#import osgeo.utils.gdal_proximity as a convenience to use as a script
from osgeo.utils.gdal_proximity import * # noqa
from osgeo.utils.gdal_proximity import main
from osgeo.gdal import deprecation_warn
deprecation_warn(‘gdal_proximity’, ‘utils’)
sys.exit(main(sys.argv))
Durring DEM merging i think
I cheked all dtm files in submodels folders and and i think all is ok
The strang one is that i did not put any --dsm flag, so why i have such error from dsm processing stage
this is the log:
[WARNING] Found a split done file in: D:\Processin\code\opensfm\split_done.txt
[WARNING] Found merged point cloud in D:\Processin\code\odm_georeferencing\odm_georeferenced_model.laz
[WARNING] Found merged orthophoto in D:\Processin\code\odm_orthophoto\odm_orthophoto.tif
[INFO] Merging DTMs
[INFO] Computing euclidean distance: D:\Processin\code\submodels\submodel_0000\odm_dem\dsm.euclideand.tif
[INFO] running gdal_proximity.py “D:\Processin\code\submodels\submodel_0000\odm_dem\dtm.tif” “D:\Processin\code\submodels\submodel_0000\odm_dem\dsm.euclideand.tif” -values -9999.0
[WARNING] Cannot compute euclidean distance file: D:\Processin\code\submodels\submodel_0000\odm_dem\dsm.euclideand.tif
[INFO] Computing euclidean distance: D:\Processin\code\submodels\submodel_0001\odm_dem\dsm.euclideand.tif
[INFO] running gdal_proximity.py “D:\Processin\code\submodels\submodel_0001\odm_dem\dtm.tif” “D:\Processin\code\submodels\submodel_0001\odm_dem\dsm.euclideand.tif” -values -9999.0
[WARNING] Cannot compute euclidean distance file: D:\Processin\code\submodels\submodel_0001\odm_dem\dsm.euclideand.tif
[INFO] Computing euclidean distance: D:\Processin\code\submodels\submodel_0002\odm_dem\dsm.euclideand.tif
[INFO] running gdal_proximity.py “D:\Processin\code\submodels\submodel_0002\odm_dem\dtm.tif” “D:\Processin\code\submodels\submodel_0002\odm_dem\dsm.euclideand.tif” -values -9999.0
[WARNING] Cannot compute euclidean distance file: D:\Processin\code\submodels\submodel_0002\odm_dem\dsm.euclideand.tif
[INFO] Computing euclidean distance: D:\Processin\code\submodels\submodel_0003\odm_dem\dsm.euclideand.tif
[INFO] running gdal_proximity.py “D:\Processin\code\submodels\submodel_0003\odm_dem\dtm.tif” “D:\Processin\code\submodels\submodel_0003\odm_dem\dsm.euclideand.tif” -values -9999.0
[WARNING] Cannot compute euclidean distance file: D:\Processin\code\submodels\submodel_0003\odm_dem\dsm.euclideand.tif
[INFO] 0 valid DEM rasters to merge
File “C:\ODM\run.py”, line 60, in
retcode = app.execute()
File “C:\ODM\stages\odm_app.py”, line 130, in execute
raise e
File “C:\ODM\stages\splitmerge.py”, line 295, in process
merge_dems(“dtm.tif”, “DTM”)
File “C:\ODM\stages\splitmerge.py”, line 272, in merge_dems
euclidean_merge_dems(all_dems, dem_file, dem_vars, euclidean_map_source=eu_map_source)
File “C:\ODM\opendm\dem\merge.py”, line 66, in euclidean_merge_dems
dst_w, dst_s, dst_e, dst_n = min(xs), min(ys), max(xs), max(ys)
ValueError: min() arg is an empty sequence
It looks like you may need to reprocess from earlier if it has failed to generate valid intermediate products.
Do you have a large SSD you can make a big pagefile on?
I used rerun all, no sucess, same error
I use HDD drive for dataset path. SSD containe only the OS, its not big enought.
for information , I try the 350 images without the split-merge option and it works perfectly.
So i think, there is something wrong with the split merge
Or my final purpose is about processing up to 11000 images. So i must use split-merge option.
