ERROR: Couldn't connect to Docker daemon - Ubuntu 20.04 fresh build
Hi folks,
I’m attempting to install on a fresh Ubuntu 20.04 build and I’m getting the following:
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
ERROR: Couldn’t connect to Docker daemon - you might need to run docker-machine start default.
What should I do next?
Have you tried adding your user to the docker group?
$ sudo apt update
$ docker-compose --version
$ sudo usermod -aG docker $USER
$ newgrp docker
Test your docker before running WebODM:
$ docker run hello-world
and then just run WebODM again
$ cd WebODM
$ ./webodm.sh start
It worked! Thanks Mel!
