ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
Hi, I’m trying to install WebODM on my desktop PC, but when I run “./webodm.sh start” I get the following error. As per instructions, I first installed Docker. I also tried to install NodeODM which works properly instead. Can you help me?
On my pc I have: Ubuntu 18.04.4 LTS;
Intel® Core™ i5-4440 CPU @ 3.10GHz × 4
93,3 GB Hard Disk
7,5GiB DDR3 RAM
~/WebODM$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
If it’s at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
Hi Leo, Did you find a solution? I too am having the same error.
EDIT: Found a solution as the problem must have been user permissions:
run “sudo ./webodm.sh start”
Luke
I have not yet found a solution, thanks for the advice, I will try to do it
Thanks a lot, I managed to solve it by doing so!
I will confess that I don’t know if there is any harm in running docker with sudo, but as a general practice, it is best to not run things via sudo if you can avoid it.
It is probably better to add the user to the docker group:
sudo usermod -aG docker ${USER}
Then log out and back in, or do so as follows:
su - ${USER}
Thanks a lot for the tip, I always ran all the commands with sudo because otherwise the terminal said got permission denied.
I suggest you add this indication in the installation guide in the Github page, in order to make it accessible even to less experienced people like me :slight_smile:
Can you do a pull request to add it? The docs are very easy to add to:
:smiley:
I’ll try
