I have been trying to process a DTM/DSM using a lightning node (I realized 32 gb memory on the tower I have would not suffice). Pasted is a link to the dropbox folder where the photos and GCPs are located. I tried using the standard GCP interface, but I keep getting error code 1. I was able to process the data without ground control points and got a high-quality image.
Here are the last few lines from the output:
File “/code/SuperBuild/src/opensfm/opensfm/io.py”, line 373, in _read_gcp_list_line
d = exif[shot_id]
KeyError: ‘DJI_0036’
File “/code/run.py”, line 56, in
app.execute()
File “/code/opendm/types.py”, line 375, in run
File “/code/opendm/types.py”, line 356, in run
File “/code/stages/run_opensfm.py”, line 29, in process
octx.reconstruct(self.rerun())
File “/code/opendm/osfm.py”, line 39, in reconstruct
self.run(‘reconstruct’)
File “/code/opendm/osfm.py”, line 19, in run
Exception:
Child returned 1
Dropbox with images and ground control points: https://www.dropbox.com/sh/ykvbceyyu68upp0/AAD1esQXwJD8eRZrCy_5Qe2Wa?dl=0
Thanks,
Matt
IMPORTANT! Having issues processing images?
- Search the forum to see if this problem happened to other users.
- Check https://github.com/OpenDroneMap/ODM/issues and https://github.com/OpenDroneMap/WebODM/issues for similar problems.
Found nothing? Great, explain in detail the problem, making sure to:
- Include a link to your images! You can use https://www.dropbox.com or https://drive.google.com. No images = difficult to help.
- Copy/paste the entire task output (not just parts of it) for everyone to read.
- Did you fine tune any parameters? Which ones?
- If applicable, what browser are you using? What operating system? How did you install the software? Be precise.
- DO NOT address your message to the moderator, a core developer, or any other specific user. The forum is a place where everyone can help answer questions, not just one particular user! Be inclusive of everyone.
- DO NOT reply to a topic that is several months old (unless you are posting the answer to a solution). Open a new topic instead.
- DO be kind and polite to others.
