Hi folks,
i am trying to render about 1900 pics in one queue.
i made two flight of area, each of them have 60/60 overlap but the second flight have changed heading by 20’. the pics are sharp and have a lot of details.
firstly i made a “small” render - about 500pics of choosed area and the results look very good.
finally i added the gcp_list.txt to the main render and after 10h i get an error:
[ERROR] Cannot read vertex count for /var/www/data/b7b90fab-0c8c-424a-b9e0-90f157b02022/mve/mve_dense_point_cloud.ply
one change between “small” and “main” are the GCP, can they broke the render?
Processing view “1310” (with colors)…
Processing view “1299” (with colors)…
Processing view “1311” (with colors)…
Processing view “1304” (with colors)…
Processing view “1306” (with colors)…
Writing final point set (11 points)…
Writing PLY file (11 verts, with colors, with normals, with confidences, with values, 0 faces)…
done.
[INFO] running /code/SuperBuild/src/elibs/mve/apps/meshclean/meshclean -t0.6 --no-clean --component-size=0 “/var/www/data/b7b90fab-0c8c-424a-b9e0-90f157b02022/mve/mve_dense_point_cloud.ply” “/var/www/data/b7b90fab-0c8c-424a-b9e0-90f157b02022/mve/mve_dense_point_cloud.filtered.ply”
MVE FSSR Mesh Cleaning (built on Sep 13 2020, 18:26:19)
Loading mesh: /var/www/data/b7b90fab-0c8c-424a-b9e0-90f157b02022/mve/mve_dense_point_cloud.ply
PLY Loader: comment Export generated by libmve
Reading PLY: 11 verts…
done.
Removing low-confidence geometry (threshold 0.6)…
Deleted 11 low-confidence vertices.
Writing mesh: /var/www/data/b7b90fab-0c8c-424a-b9e0-90f157b02022/mve/mve_dense_point_cloud.filtered.ply
Writing PLY file (0 verts, with colors, with normals, with confidences, with values, 0 faces)…
done.
[INFO] Finished mve stage
[INFO] Filtering /var/www/data/b7b90fab-0c8c-424a-b9e0-90f157b02022/mve/mve_dense_point_cloud.ply (statistical, meanK 16, standard deviation 2.5)
the example of GCP:
+proj=utm +zone=34 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
