Hello all,
Today is my first day using ODM, and while many aspects have been successful, I have not been able to create a stitched image for my multispectral datasets.
I have imagery from a Sentera Double 4k 5-band multispectral camera. When I try to upload the multispec imagery, the upload goes well for a while, then I get the “Cannot Process Dataset” error. I only get this when trying to do multispectral work-- the RGB images work great, and even using the multispec images to do a standard ortho gives me a normal image.
I will include the finer details below. Does anyone have any idea what the issue may be? I see that there are other “Cannot Process Dataset” posts, but to the best of my ability, none of them have solved my issue. I did not see any posts covering these issues in the github issues page. I am very new to image processing, so please let me know if I am overlooking something simple.
Thanks so much in advance for any help, and please let me know if I can provide any more information or if there are any edits that I should make to this post.
My system specs:
Windows 10 Home
i7
16gb ram
nvidia 2060
I am running webODM on Google Chrome and installed the program using Docker.
My current settings are:
Processing Node: Auto
Options: Multispectral
Resize Images: No (I have also tried this with Yes)
Here is a link to the images:
https://drive.google.com/drive/folders/1IwHnj7BAxAtLDUQf69PBvO9laKfv_zzd?usp=sharing
Here is the log for this event:
node-odm_1 | info: About to run: /var/www/scripts/postprocess.sh data/6a917fab-9ab8-49f1-b063-e623f663b8f9
node-odm_1 | info: About to run: 7z a -mx=0 -y -r -bd /var/www/data/6a917fab-9ab8-49f1-b063-e623f663b8f9/all.zip odm_orthophoto/odm_orthophoto.tif odm_georeferencing odm_texturing odm_dem/dsm.tif entwine_pointcloud images.json cameras.json task_output.txt log.json odm_report
node-odm_1 | info: About to run: /code/run.sh --radiometric-calibration camera --auto-boundary --pc-ept --cog --project-path /var/www/data 466cb47b-5872-4afe-bbc8-b4e9ce856ba4
worker | INFO Processing status: 40 for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | [2022-07-05 20:36:22,360: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Processing status: 40 for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | INFO Downloading all.zip for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | [2022-07-05 20:36:22,367: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Downloading all.zip for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | INFO Extracting all.zip for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | [2022-07-05 20:36:25,602: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Extracting all.zip for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | INFO Extracted all.zip for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | [2022-07-05 20:36:28,312: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Extracted all.zip for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | INFO Populated extent field with /webodm/app/media/project/5/task/8935ec6c-0ce4-4302-8c97-1fc345fa36a1/assets/odm_orthophoto/odm_orthophoto.tif for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | [2022-07-05 20:36:30,458: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Populated extent field with /webodm/app/media/project/5/task/8935ec6c-0ce4-4302-8c97-1fc345fa36a1/assets/odm_orthophoto/odm_orthophoto.tif for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | INFO Populated extent field with /webodm/app/media/project/5/task/8935ec6c-0ce4-4302-8c97-1fc345fa36a1/assets/odm_dem/dsm.tif for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | [2022-07-05 20:36:30,700: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Populated extent field with /webodm/app/media/project/5/task/8935ec6c-0ce4-4302-8c97-1fc345fa36a1/assets/odm_dem/dsm.tif for Task [RGB] (8935ec6c-0ce4-4302-8c97-1fc345fa36a1)
worker | INFO Cleaning up OAM datastore for task 8935ec6c-0ce4-4302-8c97-1fc345fa36a1
worker | [2022-07-05 20:36:34,514: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Cleaning up OAM datastore for task 8935ec6c-0ce4-4302-8c97-1fc345fa36a1
worker | INFO Cleaning up DroneDB datastore for task 8935ec6c-0ce4-4302-8c97-1fc345fa36a1
worker | [2022-07-05 20:36:34,542: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Cleaning up DroneDB datastore for task 8935ec6c-0ce4-4302-8c97-1fc345fa36a1
worker | INFO Info task 8935ec6c-0ce4-4302-8c97-1fc345fa36a1 (8935ec6c-0ce4-4302-8c97-1fc345fa36a1_ddb)
worker | [2022-07-05 20:36:34,764: INFO/ForkPoolWorker-38] worker.tasks.process_task[e4c5df18-263b-4910-a8d6-8ed0b7964363]: Info task 8935ec6c-0ce4-4302-8c97-1fc345fa36a1 (8935ec6c-0ce4-4302-8c97-1fc345fa36a1_ddb)
webapp | /usr/local/lib/python3.9/dist-packages/rio_tiler/reader.py:385: AlphaBandWarning: Alpha band was removed from the output data array
webapp | warnings.warn(
webapp | WARNING Not Found: /api/projects/5/tasks/8935ec6c-0ce4-4302-8c97-1fc345fa36a1/orthophoto/tiles/1/0/0.png
