Error "Cannot determine image format"
Hello everyone, could you help me??
I’m running the next command in a t2.large AWS instance:
docker run -ti --rm -v $(pwd):/datasets/code opendronemap/odm --project-path /datasets
but I get an error, this is the output of the command:
e[39m[INFO] Initializing OpenDroneMap app - Wed Oct 30 16:50:11 2019e[0m
e[39m[INFO] ==============e[0m
e[39m[INFO] build_overviews: Falsee[0m
e[39m[INFO] camera_lens: autoe[0m
e[39m[INFO] cameras: {}e[0m
e[39m[INFO] crop: 3e[0m
e[39m[INFO] debug: Falsee[0m
e[39m[INFO] dem_decimation: 1e[0m
e[39m[INFO] dem_euclidean_map: Falsee[0m
e[39m[INFO] dem_gapfill_steps: 3e[0m
e[39m[INFO] dem_resolution: 5e[0m
e[39m[INFO] depthmap_resolution: 640e[0m
e[39m[INFO] dsm: Falsee[0m
e[39m[INFO] dtm: Falsee[0m
e[39m[INFO] end_with: odm_orthophotoe[0m
e[39m[INFO] fast_orthophoto: Falsee[0m
e[39m[INFO] force_gps: Falsee[0m
e[39m[INFO] gcp: Nonee[0m
e[39m[INFO] ignore_gsd: Falsee[0m
e[39m[INFO] matcher_distance: 0e[0m
e[39m[INFO] matcher_neighbors: 8e[0m
e[39m[INFO] max_concurrency: 2e[0m
e[39m[INFO] merge: alle[0m
e[39m[INFO] mesh_octree_depth: 9e[0m
e[39m[INFO] mesh_point_weight: 4e[0m
e[39m[INFO] mesh_samples: 1.0e[0m
e[39m[INFO] mesh_size: 100000e[0m
e[39m[INFO] min_num_features: 8000e[0m
e[39m[INFO] mve_confidence: 0.6e[0m
e[39m[INFO] name: codee[0m
e[39m[INFO] opensfm_depthmap_method: PATCH_MATCHe[0m
e[39m[INFO] opensfm_depthmap_min_consistent_views: 3e[0m
e[39m[INFO] opensfm_depthmap_min_patch_sd: 1e[0m
e[39m[INFO] orthophoto_compression: DEFLATEe[0m
e[39m[INFO] orthophoto_cutline: Falsee[0m
e[39m[INFO] orthophoto_no_tiled: Falsee[0m
e[39m[INFO] orthophoto_resolution: 5e[0m
e[39m[INFO] pc_classify: Falsee[0m
e[39m[INFO] pc_csv: Falsee[0m
e[39m[INFO] pc_ept: Falsee[0m
e[39m[INFO] pc_filter: 2.5e[0m
e[39m[INFO] pc_las: Falsee[0m
e[39m[INFO] project_path: /datasetse[0m
e[39m[INFO] rerun: Nonee[0m
e[39m[INFO] rerun_all: Falsee[0m
e[39m[INFO] rerun_from: Nonee[0m
e[39m[INFO] resize_to: 2048e[0m
e[39m[INFO] skip_3dmodel: Falsee[0m
e[39m[INFO] sm_cluster: Nonee[0m
e[39m[INFO] smrf_scalar: 1.25e[0m
e[39m[INFO] smrf_slope: 0.15e[0m
e[39m[INFO] smrf_threshold: 0.5e[0m
e[39m[INFO] smrf_window: 18.0e[0m
e[39m[INFO] split: 999999e[0m
e[39m[INFO] split_overlap: 150e[0m
e[39m[INFO] texturing_data_term: gmie[0m
e[39m[INFO] texturing_keep_unseen_faces: Falsee[0m
e[39m[INFO] texturing_nadir_weight: 16e[0m
e[39m[INFO] texturing_outlier_removal_type: gauss_clampinge[0m
e[39m[INFO] texturing_skip_global_seam_leveling: Falsee[0m
e[39m[INFO] texturing_skip_hole_filling: Falsee[0m
e[39m[INFO] texturing_skip_local_seam_leveling: Falsee[0m
e[39m[INFO] texturing_skip_visibility_test: Falsee[0m
e[39m[INFO] texturing_tone_mapping: nonee[0m
e[39m[INFO] time: Falsee[0m
e[39m[INFO] use_3dmesh: Falsee[0m
e[39m[INFO] use_exif: Falsee[0m
e[39m[INFO] use_fixed_camera_params: Falsee[0m
e[39m[INFO] use_hybrid_bundle_adjustment: Falsee[0m
e[39m[INFO] use_opensfm_dense: Falsee[0m
e[39m[INFO] verbose: Falsee[0m
e[39m[INFO] Running dataset stagee[0m
e[39m[INFO] Loading dataset from: /datasets/code/imagese[0m
e[39m[INFO] Loading images database: /datasets/code/images.jsone[0m
e[39m[INFO] Found 696 usable imagese[0m
e[39m[INFO] Coordinates file already exist: /datasets/code/odm_georeferencing/coords.txte[0m
e[39m[INFO] Parsing SRS header: WGS84 UTM 14Ne[0m
e[39m[INFO] Finished dataset stagee[0m
e[39m[INFO] Running split stagee[0m
e[39m[INFO] Normal dataset, will process all at once.e[0m
e[39m[INFO] Finished split stagee[0m
e[39m[INFO] Running merge stagee[0m
e[39m[INFO] Normal dataset, nothing to merge.e[0m
e[39m[INFO] Finished merge stagee[0m
e[39m[INFO] Running opensfm stagee[0m
e[93m[WARNING] /datasets/code/opensfm/image_list.txt already exists, not rerunning OpenSfM setupe[0m
e[93m[WARNING] Detect features already done: /datasets/code/opensfm/features existse[0m
e[93m[WARNING] Match features already done: /datasets/code/opensfm/matches existse[0m
e[93m[WARNING] Found a valid OpenSfM tracks file in: /datasets/code/opensfm/tracks.csve[0m
e[93m[WARNING] Found a valid OpenSfM reconstruction file in: /datasets/code/opensfm/reconstruction.jsone[0m
e[39m[INFO] Already extracted camerase[0m
e[93m[WARNING] Found an undistorted directory in /datasets/code/opensfm/undistortede[0m
e[93m[WARNING] Found a valid OpenSfM NVM reconstruction file in: /datasets/code/opensfm/reconstruction.nvme[0m
e[93m[WARNING] Will skip exporting /datasets/code/opensfm/geocoords_transformation.txte[0m
e[39m[INFO] Finished opensfm stagee[0m
e[39m[INFO] Running mve stagee[0m
e[93m[WARNING] Found a valid MVE reconstruction file in: /datasets/code/mve/mve_dense_point_cloud.plye[0m
e[39m[INFO] Finished mve stagee[0m
e[39m[INFO] Running odm_filterpoints stagee[0m
e[93m[WARNING] Found a valid point cloud file in: /datasets/code/odm_filterpoints/point_cloud.plye[0m
e[39m[INFO] Finished odm_filterpoints stagee[0m
e[39m[INFO] Running odm_meshing stagee[0m
e[93m[WARNING] Found a valid ODM Mesh file in: /datasets/code/odm_meshing/odm_mesh.plye[0m
e[93m[WARNING] Found a valid ODM 2.5D Mesh file in: /datasets/code/odm_meshing/odm_25dmesh.plye[0m
e[39m[INFO] Finished odm_meshing stagee[0m
e[39m[INFO] Running mvs_texturing stagee[0m
e[39m[INFO] Writing MVS Textured file in: /datasets/code/odm_texturing/odm_textured_model.obje[0m
e[39m[INFO] Removing old tmp directory /datasets/code/odm_texturing/tmpe[0m
e[39m[INFO] running /code/SuperBuild/install/bin/texrecon /datasets/code/opensfm/reconstruction.nvm /datasets/code/odm_meshing/odm_mesh.ply /datasets/code/odm_texturing/odm_textured_model -d gmi -o gauss_clamping -t none -n 65535e[0m
/code/SuperBuild/install/bin/texrecon (built on Oct 18 2019, 23:32:28)
Load and prepare mesh:
Reading PLY: 100012 verts… 199864 faces… done.
Generating texture views:
NVM: Loading file…
NVM: Number of features: 0
terminate called after throwing an instance of ‘util::Exception’
what(): /datasets/code/opensfm/: Cannot determine image format
Aborted (core dumped)
File “/code/run.py”, line 57, in
app.execute()
File “/code/opendm/types.py”, line 370, in run
File “/code/opendm/types.py”, line 351, in run
File “/code/stages/mvstex.py”, line 97, in process
‘-n {nadirWeight}’.format(**kwargs))
Exception: Child returned 134
thank you for your help
8 GB of RAM is too little for 500 images on the texture step. You ran out of memory, I am afraid. You’ll need to use a higher memory instance. Good luck!
Hello, thank you for your response
I ran the next command on an instance with 32G of RAM and 8 CPU’s and it broke in the same stage but with a different error.
this is the output:
e[39m[INFO] Initializing OpenDroneMap app - Fri Nov 01 18:35:46 2019e[0m
e[39m[INFO] max_concurrency: 8e[0m
e[39m[INFO] orthophoto_bigtiff: IF_SAFERe[0m
e[93m[WARNING] Found a valid Bundler file in: /datasets/code/opensfm/list_r000.oute[0m
/code/SuperBuild/install/bin/texrecon (built on Aug 13 2019, 21:43:57)
Reading PLY: 100002 verts… 199846 faces… done.
Warning: Zero-length normals detected: 8 face normals, 0 vertex normals
NVM: Loading file…
terminate called recursively
File “/code/run.py”, line 56, in
app.execute()
File “/code/opendm/types.py”, line 373, in run
File “/code/opendm/types.py”, line 354, in run
This was the command:
docker run -ti --rm -v $(pwd):/datasets/code opendronemap/odm:0.8.2 --project-path /datasets
Try to run with the latest version, not 0.8.2?
opendronemap/odm:latest
I tried to run with the latest version but this was the output
2019-11-01 22:08:02,050 DEBUG: STREAM ‘IDAT’ 41 8192
2019-11-01 22:08:02,050 DEBUG: STREAM ‘IHDR’ 16 13
2019-11-01 22:08:02,051 DEBUG: STREAM ‘IDAT’ 41 8192
2019-11-01 22:08:02,051 DEBUG: STREAM ‘IHDR’ 16 13
2019-11-01 22:08:02,052 DEBUG: STREAM ‘IDAT’ 41 8192
2019-11-01 22:08:02,052 DEBUG: STREAM ‘IHDR’ 16 13
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_geocoords --transformation --proj ‘+proj=utm +zone=14 +datum=WGS84 +units=m +no_defs +type=crs’ “/datasets/code/opensfm”
[INFO] running /code/SuperBuild/src/elibs/mve/apps/makescene/makescene “/datasets/code/opensfm/reconstruction.nvm” “/datasets/code/mve”
MVE Makescene (built on Nov 1 2019, 04:32:51)
Info: Detected VisualSFM bundle format.
NVM: Loading file…
Creating output directories…
Writing MVE views…
Error loading: /datasets/code/opensfm/ (skipping view_0007.mve)
Error loading: /datasets/code/opensfm/undistorted/DJI_0136 (skipping view_0005.mve)Error loading:
/datasets/code/opensfm/Error loading: /datasets/code/opensfm/ (skipping view_0009.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0010.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0011.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0012.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0013.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0014.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0015.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0006.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0017.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0016.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0019.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0020.mve)
(skipping Error loading: /datasets/code/opensfm/ (skipping view_0021.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0018.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0022.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0023.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0024.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0025.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0026.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0027.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0028.mve)
Error loading: /datasets/code/opensfm/ (skipping view_0057.mve)
Writing MVE view: view_0002.mve…
Writing MVE view: view_0001.mve…
Writing MVE view: view_0003.mve…
Writing MVE view: view_0004.mve…
Writing MVE view: view_0000.mve…
Writing bundle file…
Writing bundle (534 cameras, 0 features): /datasets/code/mve/synth_0.out…
Done importing NVM file!
[INFO]
[INFO] ,/**
[INFO] ,
[INFO] ,/@%@&.
[INFO] ,
[INFO] ,
[INFO] ,/@&
[INFO] ,
[INFO] ,
[INFO] ,/@&&&,
[INFO] ,
[INFO] ,@&**************************************@&.
[INFO] ,@&#@@@@@@@@@%&&,
[INFO] .
[INFO] .@&&@@@@@@@@@@@@@@@@@%(@@%@@.
[INFO] .
[INFO] .
[INFO] .@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@%@@.
[INFO] .
[INFO] /@
[INFO] ,
[INFO] #@/
[INFO] #@#
[INFO] */@#
[INFO] #@//@@/%@,
[INFO] *#@#
[INFO] /@#
[INFO] (@(/%@@%%@,
[INFO] (@%%@
[INFO] @%
[INFO] (@(
[INFO] ,(@%#@/
[INFO] ,
[INFO] /@#
[INFO] ,/@&#@/
[INFO] ,
[INFO] /@#
[INFO] ,/@@@@(
[INFO] .
[INFO]
[INFO] Running dense reconstruction. This might take a while. Please be patient, the process is not dead or hung. [4/1935]
[INFO] Process is running
[INFO] running /code/SuperBuild/src/elibs/mve/apps/dmrecon/dmrecon -s4 --progress=silent --local-neighbors=2 “/datasets/code/mve”
MVE Depth Map Reconstruction (built on Nov 1 2019, 04:32:48)
Initializing scene with 5 views…
Initialized 5 views (max ID is 4), took 1ms.
Reading Photosynther file (534 cameras, 0 features)…
Reconstructing all views…
Global View Selection failed
Reconstruction took 6411ms.
Saving views back to disc…
Saving views to MVE files… done.
[INFO] running /code/SuperBuild/src/elibs/mve/apps/scene2pset/scene2pset -F4 “/datasets/code/mve” “/datasets/code/mve/mve_dense_point_cloud.ply”
MVE Scene to Pointset (built on Nov 1 2019, 04:32:59)
Using depthmap “depth-L4” and color image “undist-L4”
Initialized 5 views (max ID is 4), took 0ms.
Writing final point set (0 points)…
Writing PLY file (0 verts, with colors, with normals, with confidences, with values, 0 faces)… done.
[INFO] running /code/SuperBuild/src/elibs/mve/apps/meshclean/meshclean -t0.6 --no-clean --component-size=0 “/datasets/code/mve/mve_dense_point_cloud.ply” “/datasets/code/mve/mve_dense_poi$
t_cloud.filtered.ply”
MVE FSSR Mesh Cleaning (built on Nov 1 2019, 04:33:20)
Loading mesh: /datasets/code/mve/mve_dense_point_cloud.ply
PLY Loader: comment Export generated by libmve
Reading PLY: 0 verts… done.
Error: Mesh is empty!
app.execute()
File “/code/stages/mve.py”, line 124, in process
system.run(’%s -t%s --no-clean --component-size=0 “%s” “%s”’ % (context.meshclean_path, min(1.0, args.mve_confidence), tree.mve_model, mve_filtered_model), env_vars={‘OMP_NUM_THREADS’: a$
gs.max_concurrency})
Mm, does it work if you use --use-opensfm-dense?
with the option --use-opensfm-dense this is the last part of the output…
2019-11-03 05:51:12,150 INFO: Pruning depthmap for image DJI_0277.JPG [49/1805]
2019-11-03 05:51:12,464 INFO: Pruning depthmap for image DJI_0210.JPG
2019-11-03 05:51:14,464 INFO: Pruning depthmap for image DJI_0582.JPG
2019-11-03 05:51:15,841 INFO: Pruning depthmap for image DJI_0560.JPG
2019-11-03 05:51:16,817 INFO: Pruning depthmap for image DJI_0236.JPG
2019-11-03 05:51:21,579 INFO: Pruning depthmap for image DJI_0121 (2).JPG
2019-11-03 05:51:29,516 INFO: Pruning depthmap for image DJI_0241.JPG
2019-11-03 05:52:03,626 INFO: Merging depthmaps
[INFO] Filtering point cloud (statistical, meanK 16, standard deviation 2.5)
[INFO] running /code/build/bin/odm_filterpoints -inputFile /datasets/code/opensfm/depthmaps/merged.ply -outputFile /datasets/code/odm_filterpoints/point_cloud.ply -sd 2.5 -meank 16 -sample
0
[INFO] Writing ODM Mesh file in: /datasets/code/odm_meshing/odm_mesh.ply
[INFO] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /datasets/code/odm_filterpoints/point_cloud.ply --out /datasets/code/odm_meshing/odm_mesh.dirty.ply --depth 9 -
-pointWeight 4 --samplesPerNode 1.0 --threads 7 --linearFit
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /datasets/code/odm_meshing/odm_mesh.dirty.ply -outputFile /datasets/code/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 10000
0
[INFO] Writing ODM 2.5D Mesh file in: /datasets/code/odm_meshing/odm_25dmesh.ply
[WARNING] Maximum resolution set to GSD - 10.0% (6.38 cm / pixel, requested resolution was 5.0 cm / pixel)
[INFO] ODM 2.5D DSM resolution: 0.452297799212752
[INFO] Created temporary directory: /datasets/code/odm_meshing/tmp
[INFO] running pdal info /datasets/code/odm_filterpoints/point_cloud.ply > /tmp/tmpArc7gs.json
[INFO] Point cloud bounds are [minx: -520.059082, maxx: 1361.500732] [miny: -1235.810913, maxy: 1039.748413]
[INFO] DEM resolution is (5032, 4161), max tile size is 4096, will split DEM generation into 1 tiles
[INFO] Generating /datasets/code/odm_meshing/tmp/mesh_dsm_r0.6396456818781769_x0_y0.tif (max, radius: 0.6396456818781769, resolution: 0.452297799212752)
[INFO] running pdal pipeline -i /tmp/tmpWYnc5f.json > /dev/null 2>&1
[INFO] running gdalbuildvrt “/datasets/code/odm_meshing/tmp/tiles.vrt” “/datasets/code/odm_meshing/tmp/mesh_dsm_r0.6396456818781769_x0_y0.tif”
[INFO] running gdal_translate -co NUM_THREADS=8 --config GDAL_CACHEMAX 48.5% /datasets/code/odm_meshing/tmp/tiles.vrt /datasets/code/odm_meshing/tmp/tiles.tmp.tif
Input file size is 4161, 5032
[INFO] running gdal_translate -co NUM_THREADS=8 --config GDAL_CACHEMAX 48.5% -outsize 10% 0 /datasets/code/odm_meshing/tmp/tiles.tmp.tif /datasets/code/odm_meshing/tmp/tiles.small.tif
[INFO] running gdal_fillnodata.py -co NUM_THREADS=8 --config GDAL_CACHEMAX 48.5% -b 1 -of GTiff /datasets/code/odm_meshing/tmp/tiles.small.tif /datasets/code/odm_meshing/tmp/tiles.small_fi
lled.tif
[INFO] running gdalbuildvrt -resolution highest -r bilinear “/datasets/code/odm_meshing/tmp/merged.vrt” “/datasets/code/odm_meshing/tmp/tiles.small_filled.tif” “/datasets/code/odm_meshing/
tmp/tiles.tmp.tif”
[INFO] running gdal_translate -co NUM_THREADS=8 --config GDAL_CACHEMAX 48.5% /datasets/code/odm_meshing/tmp/merged.vrt /datasets/code/odm_meshing/tmp/tiles.tif
[INFO] Starting smoothing…
[INFO] Smoothing iteration 1 [1/1806]
[INFO] Completed smoothing to create …/datasets/code/odm_meshing/tmp/mesh_dsm.tif in 0:00:07.839898
[INFO] Completed mesh_dsm.tif in 0:02:27.549226
[INFO] Creating mesh from DSM: /datasets/code/odm_meshing/tmp/mesh_dsm.tif
[INFO] running /code/SuperBuild/src/dem2mesh/dem2mesh -inputFile /datasets/code/odm_meshing/tmp/mesh_dsm.tif -outputFile /datasets/code/odm_meshing/odm_25dmesh.dirty.ply -maxTileLength 400
0 -maxVertexCount 100000
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /datasets/code/odm_meshing/odm_25dmesh.dirty.ply -outputFile /datasets/code/odm_meshing/odm_25dmesh.ply -removeIslands -decimateMesh
100000
/code/SuperBuild/install/bin/texrecon (built on Nov 1 2019, 04:32:12)
Reading PLY: 99560 verts… 198972 faces… done.
NVM: Loading file…
what(): terminate called recursively
app.execute()
