Error after over 91 hours
Having a go at the dataset here:
It failed for reasons not obvious too me (Check failed: num_nonzeros_ >= 0, and the reasons given do not apply), when adding images to the reconstruction -
[Κιλκίς - Σταθμός Μουριών - 17/11/2022]
171 images 91:24:03
Cannot process dataset
|Created on:|30/12/2022, 11:15:52|
|Processing Node:|node-odm-1 (manual)|
|Options:|auto-boundary: true, crop: 5, dem-resolution: 2.0, dtm: true, feature-quality: ultra, gps-accuracy: 6, min-num-features: 20000, orthophoto-resolution: 1.0, pc-quality: ultra, pc-rectify: true, use-3dmesh: true|
2023-01-03 06:11:18,125 INFO: DJI_20221117143611_0005.JPG resection inliers: 238569 / 239578
2023-01-03 06:11:21,918 INFO: Adding DJI_20221117143611_0005.JPG to the reconstruction
2023-01-03 06:11:59,716 INFO: -------------------------------------------------------
2023-01-03 06:12:08,233 INFO: DJI_20221117143351_0041.JPG resection inliers: 235431 / 236112
2023-01-03 06:12:12,123 INFO: Adding DJI_20221117143351_0041.JPG to the reconstruction
2023-01-03 06:12:54,861 INFO: -------------------------------------------------------
2023-01-03 06:13:05,863 INFO: DJI_20221117143724_0055.JPG resection inliers: 220102 / 220228
2023-01-03 06:13:12,166 INFO: Adding DJI_20221117143724_0055.JPG to the reconstruction
2023-01-03 06:13:31,133 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
D:\a\ODM\ODM\SuperBuild\src\ceres\internal\ceres\block_sparse_matrix.cc:80 Check failed: num_nonzeros_ >= 0
There is plenty of overlap in the images, they are in focus, and there were Millions of features in each image, with up to 300,000 common features when matching.
389GB of memory available including virtual.
Console log available if useful.
Graph of final 24 hours resource use
It could be that the limit number of elements in the Ceres solution matrix was exceeded. If you can try to limit in some way (by changing the feature type or manually adjusting the opensfm configuration if you dare) the number of features or matches to verify if that is the problem.
Life is too short to try ultra settings again :wink: I’ve got other projects to process.
I did run at medium feature quality and it all came out at one level, which is what the OP had a problem with.
When does one know, that WebODM, is finished, by virtue of poor data or errors.
I have 1200 photos, that worked well in WebODM 1.9.3(?), that’s been cooking for 20.5 hours, with the bar indicator stuck at the same spot(one space past "Processing ), which is always the typical location before the program begins it’s finishing processing.
My problem is, the last timed indicator is now about 11 hours ago, and the last 9 lines is [INFO], with no time designation, and no new line entries for at least 5 or so hours…
How can one tell that the program, has in fact finished or can not finish?
If there is no error indicator or hard crash, does this mean the computations are continuing, with no timed processing steps?
In the WebODM3, I used all defaults, including “High Resolution”, something I rarely use.
BTW, are measure points “scalable”, and how can one be very “certain”, that the points are/are not “hot”?
In Windows you can check details in Task Manager to make sure CPU and memory usage, commits etc are changing. If they are not changing at, all it’s a good indication things have ground to a halt and you need to start again with
different settings.
Also, in another thread I posted this:
The first half isn’t always 1.5%, but the 2nd half is always a lot less time than the 1st.
Also here, where no movement for over 18 hours:
