Error after 45 Hours
IMPORTANT! Having issues processing images?
  1. Search the forum to see if this problem happened to other users.
  2. Check Issues · OpenDroneMap/ODM · GitHub and Issues · OpenDroneMap/WebODM · GitHub for similar problems.
Processes great for 45 hours nearly finished then error appeared
  1. Include a link to your images! You can use https://www.dropbox.com or https://drive.google.com. No images = difficult to help.
  2. Copy/paste the entire task output (not just parts of it) for everyone to read.
  3. Did you fine tune any parameters? Which ones?
  4. If applicable, what browser are you using? What operating system? How did you install the software? Be precise.
  5. DO NOT address your message to the moderator, a core developer, or any other specific user. The forum is a place where everyone can help answer questions, not just one particular user! Be inclusive of everyone.
  6. DO NOT reply to a topic that is several months old (unless you are posting the answer to a solution). Open a new topic instead.
  7. DO be kind and polite to others.
Remove this notice before posting. Thank you so much!
Please read the posting instructions? :pray:
