Error 137 (out of memory) in windows or WSL even with 50GB RAM
Hello
I just got a new machine (i9, 64GB RAM) and tried to run a dataset in WebODM. The same dataset was processed correctly in a Mac with 32GB RAM.
I tried using Docker for Windows and also installing Ubuntu in WSL-2 and then installing WebODM inside Ubuntu. In WSL, I can see that I have 50GB of RAM.
I tried with and without splitting, same error. Also tried max-concurrency=1, same error.
here are the last lines of the output:
2021-02-09 16:13:52,947 DEBUG: Computing sift with threshold 0.1
app.execute()
File “/code/opendm/types.py”, line 360, in run
File “/code/opendm/types.py”, line 341, in run
File “/code/stages/splitmerge.py”, line 59, in process
File “/code/opendm/osfm.py”, line 279, in feature_matching
self.run(‘detect_features’)
File “/code/opendm/osfm.py”, line 27, in run
system.run(‘%s/bin/opensfm %s “%s”’ %
Exception: Child returned 137
So: is error 137 only for out-of-memory? If not, what else? Is it possible that I’m missing any dependency?
thanks
Hmm, can you update your docker image again, and maybe do another git pull for your WSL2 image?
Aannnnd… it works!
thanks
