Error 134
Hello, im processing 300 images to make a 3D model of a 150x150 meter ground and processing doesnt finish. my settings
Options: depthmap-resolution: 1000, mesh-octree-depth: 11, mesh-size: 300000, pc-quality: high, use-3dmesh: true
Point visibility checks 61550094 (99.92%, 6m, ETA 286ms)…
Point visibility checks 61586665 (99.98%, 6m3s, ETA 73ms)…
Point visibility checks 61599069 (100%, 6m4s65ms)
21:42:17 [App ] MEMORYINFO: {
21:42:17 [App ] VmPeak: 10378980 kB
21:42:17 [App ] VmSize: 9657112 kB
21:42:17 [App ] } ENDINFO
[INFO] Finished openmvs stage
[INFO] Filtering /www/data/b35d5170-de98-44a4-b809-a40e3eeecce4/opensfm/undistorted/openmvs/scene_dense_dense_filtered.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] Splitting point cloud filtering in chunks of 250000 vertices
[INFO] running pdal split -i “/www/data/b35d5170-de98-44a4-b809-a40e3eeecce4/opensfm/undistorted/openmvs/scene_dense_dense_filtered.ply” -o “/www/data/b35d5170-de98-44a4-b809-a40e3eeecce4/odm_filterpoints/parts/part.ply” --capacity 250000 --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar,views=uchar”
double free or corruption (out)
Aborted
app.execute()
File “/code/opendm/types.py”, line 360, in run
[Previous line repeated 2 more times]
File “/code/opendm/types.py”, line 341, in run
File “/code/stages/odm_filterpoints.py”, line 24, in process
point_cloud.filter(inputPointCloud, tree.filtered_point_cloud,
File “/code/opendm/point_cloud.py”, line 120, in filter
point_cloud_submodels = split(input_point_cloud, partsdir, “part.ply”, capacity=VERTEX_THRESHOLD, dims=dims)
File “/code/opendm/point_cloud.py”, line 66, in split
system.run(cmd)
Exception: Child returned 134
double free or corruption (!prev)
/code/run.sh: line 5: 657018 Aborted python3 $RUNPATH/run.py “[email protected]
Sorry for the trouble! Could you please start with giving me a bit more information about your system?
For instance:
  1. Operating System and Version
    eg: Windows 11, MacOS 15.1, Ubuntu Linux 20.04LTS, etc…
  2. WebODM Install Method
  3. WebODM/ODM Version
    eg: WebODM v1.9.11 Build 51, ODM v2.7.1, etc…
  4. Procesing Node
    eg: Automatic, Lightning, local (node-odm-1), etc…
fresh/clean install from WEBODM LIVEUSB ISO on a IBM X3650 M3 server with 164GB RAM and 2 Xeon Processors, no GPU. WebODM 1.7.1 Processing node node-odm-1 (same server)
im double posting since the error is different from 139
Different code, but both can indicate a memory issue, so related, I think.
