Boa noite, alguém sabe me informar como faço pra resolver esse erro durante a instalação do WEB ODM? / Good night, can anyone tell me how I can resolve this error during the installation of WEB ODM?
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-odm=1
File “docker\api\client.py”, line 214, in _retrieve_server_version
File “docker\api\daemon.py”, line 181, in version
File “docker\utils\decorators.py”, line 46, in inner
File “docker\api\client.py”, line 237, in _get
File “requests\sessions.py”, line 543, in get
File “requests\sessions.py”, line 530, in request
File “requests\sessions.py”, line 643, in send
File “requests\adapters.py”, line 439, in send
File “urllib3\connectionpool.py”, line 670, in urlopen
File “urllib3\connectionpool.py”, line 392, in _make_request
File “http\client.py”, line 1255, in request
File “http\client.py”, line 1301, in _send_request
File “http\client.py”, line 1250, in endheaders
File “http\client.py”, line 1010, in _send_output
File “http\client.py”, line 950, in send
File “docker\transport\npipeconn.py”, line 32, in connect
File “docker\transport\npipesocket.py”, line 23, in wrapped
File “docker\transport\npipesocket.py”, line 72, in connect
File “docker\transport\npipesocket.py”, line 52, in connect
pywintypes.error: (2, ‘CreateFile’, ‘O sistema n▒o pode encontrar o arquivo especificado.’)
File “docker-compose”, line 3, in
File “compose\cli\main.py”, line 81, in main
File “compose\cli\main.py”, line 200, in perform_command
File “compose\cli\command.py”, line 60, in project_from_options
File “compose\cli\command.py”, line 152, in get_project
File “compose\cli\docker_client.py”, line 41, in get_client
File “compose\cli\docker_client.py”, line 170, in docker_client
File “docker\api\client.py”, line 197, in init
File “docker\api\client.py”, line 221, in _retrieve_server_version
docker.errors.DockerException: Error while fetching server API version: (2, ‘CreateFile’, ‘O sistema n▒o pode encontrar o arquivo especificado.’)
[5760] Failed to execute script docker-compose
