[Errno 2] No such file or directory
I am running ODM on Linux using singularity (high performance computing environment 64GB RAM). I am processing drone images. I tried different datasets (20, 50, 250 images) , and got similar results " FileNotFoundError: [Errno 2] No such file or directory: ‘/datasets/code/odm_meshing/odm_mesh.dirty.ply’"
My command was : singularity run --bind /user/khaledei/Desktop/datasets:/datasets odm_latest.sif --project-path /datasets
INFO] Initializing ODM - Mon Jan 25 21:47:55 2021
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 32
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: code
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] primary_band: auto
[INFO] project_path: /datasets
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /datasets/code/images
[INFO] Loading 21 images
[INFO] Wrote images database: /datasets/code/images.json
[INFO] Found 21 usable images
[INFO] Parsing SRS header: WGS84 UTM 10N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 5472px
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 2736’, ‘feature_min_frames: 8000’, ‘processes: 32’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘depthmap_method: PATCH_MATCH’, ‘depthmap_resolution: 1368’, ‘depthmap_min_patch_sd: 1’, ‘depthmap_min_consistent_views: 3’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata “/datasets/code/opensfm”
error
[INFO] Writing ODM Mesh file in: /datasets/code/odm_meshing/odm_mesh.ply
[INFO] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /datasets/code/odm_filterpoints/point_cloud.ply --out /datasets/code/odm_meshing/odm_mesh.dirty.ply --depth 11 --pointWeight 4.0 --samplesPerNode 1.0 --threads 31 --linearFit
[ERROR] Failed to open file: /scratch/4923687/PR_c44wiT
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /datasets/code/odm_meshing/odm_mesh.dirty.ply -outputFile /datasets/code/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 200000
Warning: In /build/vtk6-dZa2pz/vtk6-6.3.0+dfsg2/IO/PLY/vtkPLYReader.cxx, line 124
vtkPLYReader (0x55cf7fb37240): Could not open PLY file
ERROR: In /build/vtk6-dZa2pz/vtk6-6.3.0+dfsg2/Common/ExecutionModel/vtkExecutive.cxx, line 781
vtkCompositeDataPipeline (0x55cf7fb38860): Algorithm vtkPLYReader(0x55cf7fb37240) returned failure for request: vtkInformation (0x55cf7fb3a8e0)
Debug: Off
Modified Time: 111
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FROM_OUTPUT_PORT: 0
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
ERROR: In /build/vtk6-dZa2pz/vtk6-6.3.0+dfsg2/Filters/Core/vtkPolyDataConnectivityFilter.cxx, line 106
vtkPolyDataConnectivityFilter (0x55cf7fb3b500): No points!
ERROR: In /build/vtk6-dZa2pz/vtk6-6.3.0+dfsg2/IO/PLY/vtkPLYWriter.cxx, line 111
vtkPLYWriter (0x55cf7fb40510): No data to write!
app.execute()
File “/code/opendm/types.py”, line 361, in run
File “/code/opendm/types.py”, line 342, in run
File “/code/stages/odm_meshing.py”, line 24, in process
File “/code/opendm/mesh.py”, line 186, in screened_poisson_reconstruction
os.remove(outMeshDirty)
any idea how I I can solve this issue
I´ve got a similar error when trying to run from snap
[INFO] Initializing ODM - Tue Feb 23 09:31:51 2021
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dsm: False
[INFO] dtm: False
[INFO] gcp: None
[INFO] geo: None
[INFO] max_concurrency: 4
[INFO] merge: all
[INFO] name: code
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] skip_report: False
[INFO] tiles: False
[INFO] time: False
[WARNING] Directory code does not exist. Creating it now.
File “/snap/opendronemap/63/odm/run.py”, line 46, in
system.mkdir_p(os.path.abspath(args.project_path))
File “/snap/opendronemap/63/odm/opendm/system.py”, line 105, in mkdir_p
os.makedirs(path)
File “/usr/lib/python3.8/os.py”, line 223, in makedirs
mkdir(name, mode)
OSError: [Errno 30] Read-only file system: ‘/code’
