Empty Orthophoto and DSM
Hi
I used webODM in this case (though I am also using ODM and don’t think this makes a difference here) and was able to complete full process without any errors. Looks like the log came clean and I was able to download all assets, but the actual orthophoto file and DSM file themselves, i.e. the TIF, are empty (2kB and not 100s of MB). I am not sure what happened since everything seemed normal. Trying to look at the outputs in webODM I get a “bad request message” at the top left.
log file attached: log_empty_outputs.txt - Google Drive
Has anyone come across this? Can anyone point to another relevant thread?
Thank you
This could be lots of things. Is this a dataset you can share for testing?
It just happened again today using ODM (not webODM) on this data set:
I’m running ODM 0.9.8 on Ubuntu 18.04, 32GB. I ran with default params except --dsm and --dtm options only.
ortho, dsm dtm were on the order of KB and not 100s of MB. I accidentally did not save the log but I have all output folders. Couldn’t find the log there. Is there a place where the log from the run is automatically saved?
I’ll upload the other data set and post it here. I already linked in the previous post to the log of that run.
Attached is the data of my first post. It has two sets of JPG images. Using both sets invokes a multi-camera mode in ODM with the log message:
 [INFO]    Increasing matcher neighbors to 16 to accomodate multi-camera setup
 [INFO]    Multi-camera setup, using BOW matching
As noted it ran all the way through as if all was well. The multi camera mode seemed to have worked, cameras.json file is:
    "sony a7_lower_left 3776 2502 brown -5537. agro_a7": {
        "p2": 0.0,
        "p1": 0.0,
        "width": 3776,
        "projection_type": "brown",
        "height": 2502,
        "k3": 0.0,
        "k2": 0.0,
        "k1": 0.0,
        "focal_y": -5537.604456824513,
        "focal_x": -5537.604456824513,
        "c_y": 0.0,
        "c_x": 0.0
    "sony dsc-rx0 4800 3200 brown 0.6666 rx0": {
        "p2": 0.0,
        "p1": 0.0,
        "width": 4800,
        "height": 3200,
        "k3": 0.0,
        "k2": 0.0,
        "k1": 0.0,
        "focal_y": 0.6666666666666666,
        "focal_x": 0.6666666666666666,
        "c_y": 0.0,
        "c_x": 0.0
Also, textured model was created:
https://drive.google.com/file/d/1ANH9rD5EZnsxV4TTPjzchvA4YQTFJwDN/view?usp=sharing
Since this happened in two data sets and webODM and ODM - I suspect there may be a chance it is not data related, but I may be wrong.
I have the same problem. Have you resolved?
Actually I wasn’t able to point out why it happened. Subsequent data sets in multi-camera did not yield this phenomenon.
Are you using multi-camera?
Thanks for answering. No, I’m not using multi-camera.
