I am a dev who has installed webodm with docker.
as you can see the node is offline and I know why.
the node’s real name is “webodm_agriculture_node-odm_1”
so I only need to change the hostname from “webodm-node-odm-1” to “webodm_agriculture_node-odm_1” but that fix will only work on my device. I want a fix that will apply automatically when I pass my webodm version to another user.
I tried to fix the name in the boot.py file but it didn’t work even after I used the command:
docker build -t opendronemap/webodm_webapp .
