hello,
iam running into a problem that i cant solve…
Till now i always used the ultra quality mode on webodm and had no problems.
But this time i dont really know that the problem is.
If i run the project with high settings i get a perfectly fine orthophoto, DTM and 3d model
[Only can add one image as a new user…]
But if a run the same data set on ultra settings the DTM model is missing some parts in the right corner. The Orthophoto and the 3d model are fine.
Does someone know what the problem could be?
Thank you for your help!
Settings High
[INFO] Initializing ODM - Thu Apr 14 06:52:39 2022
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 2.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: True
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 806632d3-6814-4599-85e0-5e17284feb43
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 2.0
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: high
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
Settings Ultra
[INFO] Initializing ODM - Sat Apr 30 08:07:23 2022
[INFO] cameras: {}
[INFO] cog: True
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_resolution: 1.0
[INFO] dsm: True
[INFO] dtm: True
[INFO] feature_quality: ultra
[INFO] gcp: None
[INFO] geo: None
[INFO] merge: all
[INFO] name: d409bb61-948b-4ea7-bfb0-efc54a7e0e87
[INFO] orthophoto_png: True
[INFO] orthophoto_resolution: 1.0
[INFO] pc_classify: True
[INFO] pc_ept: True
[INFO] pc_quality: ultra
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] tiles: False
[INFO] time: False
