Dear all,
We produced DSM and the value are always very high values (around 2000m), in reality they should have a elevation around 0m. Do you know why it like this?
Also the final product always us WGS/UTM as projection system. but the image has geo.txt using local projection (amersfoort RD new). Is there any force reprojection in the end?
It is hard to say without seeing your input data and parameters.
I will say that in general, the elevation values should closely match the GCPs or the images provided.
No, we currently do not support anything other than the most appropriate local UTM CRS for processing. You will need to transform the data products after processing if you need another CRS.
Basically we didn’t supply any GCPs since they are large format dataset and EO parameter has been optimised. We could create good DSM using other commercial software. Is that not possible to create good DSM without supply GCPs?
Thanks for let us know that it is possible without GCPs! We might will try it
Our file were processed using following command: docker exec -it fbaf3c96fafc python3 /code/run.py --project-path /datasets project --dsm --geo /code/geo.txt
the images are 80% overlapped in a row, and all large format datasets (>100megapixels)
the geo.txt is just normal geo.txt like this EPSG:28992
364495.tif 103062.195 483859.266 4375.39 -0.0626 -0.4109 0.3094
Do you know what could be the important parameters that we could adjust?
Looks like upstream OpenSFM doesn’t support the Vexcell UltraCam Eagle Mark 3 natively, so I’m opening an inquiry to see how we might go about adding the sensor, since you’re at least the third person to be using data from that sensor this year so far: https://github.com/mapillary/OpenSfM/issues/808
Hi Saijn,
Do you know if it is possible we just supply the camera.json file ourselves and OpenSFM can handle this camera?
We tried to give a camera.json like below:
Pairs: []
Reconstruction: []
The images we got are pansharpened product, so we used the same camera parameter as Panchromatic Camera, and the folowing camera calibration report is delivered together with image provider:
The only doubt that we had is the ‘c_x’, ‘c_y’. we just assume that they are x_ppa and y ppa. the other parameters are pretty correct.
Do you see anything incorrect?
I don’t know what the implications of using the pan camera parameters would be, but it might be useful to run the process without calibration parameters and see what the output calibration parameters end up being and compare them.
Hi Saijin,
You were have a inquiry about how to add 4 different focal length to OpenSFM, do you know what to add if we want to use the single focal length (210mm) in OpenSFM? Could we try ourselves?
Best regards,
Yi
This was translated in ODM to the following camera.json:
“v2 vexcel imaging gmbh ultracam eagle mark 3 f210 26460 17004 brown 0.0 rgb”: {
“projection_type”: “brown”,
“width”: 26460,
“height”: 17004,
“focal_x”: 0.85,
“focal_y”: 0.85,
“c_x”: 0.0,
“c_y”: 0.0,
“k1”: 0.0,
“k2”: 0.0,
“p1”: 0.0,
“p2”: 0.0,
“k3”: 0.0
This is very similar to the output obtained following smathermather’s suggestion (see Yi’s comment above)
The output DSM however still shows large values of 2450m to 2550m, while a reference DSM shows values of -2m to 30m.
ODM is obviously designed for handling drone images, while the images we try to feed it are taken from an airplane with a much larger sensor. Can altitude play a role in this issue? Our images are taken at 4000-5000m above ground, while I see values of ~200m above ground in e.g. this example dataset (reffered to in ODMData: GitHub - pierotofy/drone_dataset_brighton_beach
