DroneDB Registry Self-Host Help
Has anybody configured a publically visible instance on Registry on a windows machine ?
I have configured a DDNS to point to my home router and can port-forward successfully to a WebODM Docker instance but I’m having no luck connecting to a Registry Docker instance.
I can connect to a Registry Docker instance across my local network but I need to be able to access my database remotely, without using a VPN.
Have you checked the Running In Production section to ensure the proper port is opened for Registry?:
I have opened port 5000 TCP for all inbound and outbound connections in Windows Firewall with no change.
I have also (briefly) tried turning off the firewall entirely and that makes no difference.
Then you might need to be looking at your Modem/Router.
In my router I am forwarding port 5000 to the local IP of the machine hosting the Docker instance. Exactly the same way I am forwarding port 8000 to the local IP of the machine hosting WebODM.
Looks like I have bigger problems right now; on a fresh install using default user:pass, I can create a new dataset, upload imagery and preview on the map screen. When I then disconnect/reconnect using the same machine (or different machine) I get ’ TypeError: Failed to Fetch ’
I wasn’t sure if this was a cookies or cache related thing but I get the same result using Edge browser.
From within Docker I’ve tried deleting the container / image / volume to start from scratch but I keep getting the same result…
Looks like the TypeError is related to setting the external URL in .env
If I comment out the external URL line in .env I can at least get to my database. Back to figuring out how to make Registry respond to a public IP
In a nutshell, it appears it can’t be done in Docker Desktop (Windows machine)
I currently have an instance of DroneDB running on a Linux VM within Windows 10 that can be reached from the internet. In this particular setup I have multiple network cards installed so have been able to assign a dedicated network card to the VM which greatly simplifies the network configuration.
Now to figure out how to access user management for creating a dataset that isn’t linked to the admin user.
