DroneDB no such column and entries not found
Compiled and attempting to use DroneDB with mixed success:
[email protected]:/path/code# ~/ddb/build/./ddb init
no such column: TRUE
[email protected]:/path/code# ~/ddb/build/./ddb add images/
Table 'entries' not found (not a valid database: /path/code/./.ddb/dbase.sqlite)
Any thoughts on what might have gone wrong?
Huh, this looks like a bug. What if you switch directory:
cd ~/ddb/build
And then ./ddb init ?
~/ddb/build# ./ddb init
Mm, could you run the command with the verbose flag to get more info?
./ddb init --verbose
Also, is there a .ddb directory in the current directory? Does removing it resolve this?
I deleted the .ddb directory and then ran:
2019-10-29 19:04:03.053 DEBUG [31383] [ddb::[email protected]] Checking if .ddb directory exists...
2019-10-29 19:04:03.054 DEBUG [31383] [ddb::[email protected]] .ddb created
2019-10-29 19:04:03.054 DEBUG [31383] [ddb::[email protected]] Checking if dbase exists...
2019-10-29 19:04:03.054 DEBUG [31383] [ddb::[email protected]] Creating .ddb/dbase.sqlite
2019-10-29 19:04:03.054 DEBUG [31383] [Database::[email protected]] Opening connection to .ddb/dbase.sqlite
2019-10-29 19:04:03.054 DEBUG [31383] [Database::[email protected]] About to create tables...
2019-10-29 19:04:03.055 DEBUG [31383] [Database::[email protected]] Closing connection to .ddb/dbase.sqlite
2019-10-29 19:04:03.055 VERB  [31383] [ddb::[email protected]] Exception caught, cleaning up...
I wonder if it’s related to the version of sqlite3; for reference here’s what I’m using:
2019-10-29 15:14:22.841 VERB  [11018] [[email protected]] DDB v0.9.0
2019-10-29 15:14:22.841 VERB  [11018] [[email protected]] SQLite version: 3.29.0
2019-10-29 15:14:22.841 VERB  [11018] [[email protected]] SpatiaLite version: 4.3.0a
I’ve replaced the “TRUE” constant with “1”, which might work with older versions. Update/rebuild/retry? https://github.com/uav4geo/DroneDB/commit/3bf5b3c837db36b3ba512b1e8965f494d8733834
That’s a little better!
2019-10-29 20:30:45.182 VERB  [5710] [[email protected]] DDB v0.9.0
2019-10-29 20:30:45.182 VERB  [5710] [[email protected]] SQLite version: 3.22.0
2019-10-29 20:30:45.182 VERB  [5710] [[email protected]] SpatiaLite version: 4.3.0a
2019-10-29 20:30:45.182 DEBUG [5710] [ddb::[email protected]] Checking if .ddb directory exists...
2019-10-29 20:30:45.182 DEBUG [5710] [ddb::[email protected]] .ddb created
2019-10-29 20:30:45.182 DEBUG [5710] [ddb::[email protected]] Checking if dbase exists...
2019-10-29 20:30:45.182 DEBUG [5710] [ddb::[email protected]] Creating .ddb/dbase.sqlite
2019-10-29 20:30:45.182 DEBUG [5710] [Database::[email protected]] Opening connection to .ddb/dbase.sqlite
2019-10-29 20:30:45.187 DEBUG [5710] [Database::[email protected]] About to create tables...
2019-10-29 20:30:45.372 DEBUG [5710] [Database::[email protected]] Created tables
2019-10-29 20:30:45.372 DEBUG [5710] [Database::[email protected]] Closing connection to .ddb/dbase.sqlite
Initialized empty database in .ddb
Oooh, new error:
terminate called after throwing an instance of 'Exiv2::BasicError<char>'
  what():  No namespace info available for XMP prefix `drone-dji'
Aborted (core dumped)
Progress :clap:
If you send me a link (even privately) to a few of the images (5-10, not the entire dataset) I can try to troubleshoot this further.
Haven’t done much testing outside of datasets captured with DJI equipment.
You have the link. It’s on the server you are oh so familiar with. :slight_smile:
