DroneDB example datasets not accessible (possible bug in registry)
I wanted to browse the example datasets on DroneDB, but when I visited the Brighton Beach dataset at Hub I got the following error:
To aid with diagnostics, I tried to check the Public organization on my own dronedb deployment (the registry Docker image for which I just updated this afternoon). Here’s the error message I saw in the logs:
[23:10:11 ERR] Exception in Organizations controller Get('public')
System.ArgumentNullException: Value cannot be null. (Parameter 'source')
   at System.Linq.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument)
   at System.Linq.Enumerable.Any[TSource](IEnumerable`1 source, Func`2 predicate)
   at Registry.Web.Services.Managers.AuthManager.RequestAccessToOrganization(Organization org, AccessType access, User user) in /Registry/Registry.Web/Services/Managers/AuthManager.cs:line 149
   at Registry.Web.Services.Managers.AuthManager.RequestAccess[T](T obj, AccessType access, User user) in /Registry/Registry.Web/Services/Managers/AuthManager.cs:line 86
   at Registry.Web.Services.Managers.AuthManager.RequestAccess[T](T obj, AccessType access) in /Registry/Registry.Web/Services/Managers/AuthManager.cs:line 95
   at Registry.Web.Services.Managers.OrganizationsManager.Get(String orgSlug) in /Registry/Registry.Web/Services/Managers/OrganizationsManager.cs:line 76
   at Registry.Web.Controllers.OrganizationsController.Get(String orgSlug) in /Registry/Registry.Web/Controllers/OrganizationsController.cs:line 60
Based on the message, I think it’s the same problem.
I seem to be able to access the link without the error message shown.
I tried again, and got the same error. I then logged out, and tried the link, and I was successful. Does it work for you when you are logged in?
I’m now wondering if it’s something about Safari?
Seems to work if I’m logged in or not. Using Chrome on Arch Linux though.
Transient issue?
I’m good with FireFox on Alpine Linux currently… Same for FireFox on Android.
Working now on both. Wacky stuff. Thanks for checking!
