DroneDB and WebODM
Had a question. I have put up a server with DroneDB and can connect just fine to it. I was able to upload data to the DB. Earlier I was able to do a DroneDB import and connect to the db. I go into in the plugin, add my login and the server IP, I click verify config and says succeed. I hit save configuration. Now when I go to DroneDB import it just goes to a blank white page within WebODM. I even uninstalled and re-installed and tried with just the default plugin info but still just goes to a blank screen. Any ideas?
What port are you using? Are you resolving with host name, IP, localhost, etc?
  1. I can access the DroneDB from both local and public IP. I get succeed in the DroneDB plugin in WebODM. Even after uninstalling and reinstalling and leaving it with the default app.hub when I click DroneDB import it just goes to a white screen.
Are any error messages printed on the screen or in the HTML Inspector of your browser?
Oh this is in WebODM desktop client, not through the browser.
Here is before
Then after I click DroneDB Import
Happens even with default info
I have the exact same problem.
What version is everyone using?
I’m on the latest, I believe 1.9.16 and nodes are version 3.
same here with me. the plugin shows and when i try and export it says loading, but the files do not transfer to the hub. any help would be appreciated.
For the sharing part, this could be a bug in the Registry software; this is what shows up on the stack trace on the server side:
[03:46:05 ERR] Exception in Share controller Upload('FcNYhCZXxPIqkffRv4otCqA1aOR1', 'odm_dem\dsm.tif', '{file?.FileName}')
System.InvalidOperationException: Cannot find just added file!
   at Registry.Web.Services.Managers.ObjectsManager.AddNew(String orgSlug, String dsSlug, String path, Stream stream) in /Registry/Registry.Web/Services/Managers/ObjectsManager.cs:line 225
   at Registry.Web.Services.Managers.ShareManager.Upload(String token, String path, Stream stream) in /Registry/Registry.Web/Services/Managers/ShareManager.cs:line 448
   at Registry.Web.Controllers.ShareController.Upload(String token, String path, IFormFile file) in /Registry/Registry.Web/Controllers/ShareController.cs:line 92
   at Registry.Web.Controllers.ShareController.Upload(String token, String path, IFormFile file) in /Registry/Registry.Web/Controllers/ShareController.cs:line 93
Something is wrong with DroneDB library because that error message is more like an assertion than actual check:
            // Write down the file
            await using (var localFileStream = File.OpenWrite(localFilePath))
                await stream.CopyToAsync(localFileStream);
            _logger.LogInformation("File saved, adding to DDB");
            ddb.AddRaw(localFilePath);
            _logger.LogInformation("Added to DDB, checking entry now...");
            var entry = await ddb.GetEntryAsync(path);
            if (entry == null)
                throw new InvalidOperationException("Cannot find just added file!");
Basically after adding it to DDB it asserts that it was added. Do you have a repro for this issue?
Im not sure what a repro is? Sorry, not very savvy with this type of stuff.
It’d be steps to reproduce the issue and any data we may need to replicate your exact issue if it doesn’t occur with all data.
