Downloading assets
I just switched to windows native ODM. When downloading my first set of assets, it did so in a zip file and everything worked fine. Since then, it doesn’t do the zip file if I pick one asset or all assets. It names everything as a “file” type. The drop down in the save menu only gives me . All file types as an option.
How do I fix this?
Mm, strange. What happens if you restart the app?
You should be able to rename them with a .zip at the end to have them work in Explorer’s zip function, if indeed they’re being exported properly. So, those aren’t lost yet :slight_smile:
Ok thanks. Doing a right click-> Rename and adding .zip worked. Wonder why the .zip was lost after I downloaded the first one.
I did restart and it did the same thing.
A second restart and now it seems to be working the way it should.
🤷 Computers.
Glad you’re running smooth. Could you please let us know if this happens again?
