Thanks, the tractor has suddenly appeared! I’ve never needed to do that previously, my subject has been visible initially. Is this something that needs to be done due to the latest version update?
It looks like I need to add some more images to fill in holes and remove the ground from under the canopy
I added more images to try to get rid of some of the holes and incorrectly placed textures, but it crashed after 18 h 36m. Below is the end of the console log from the final successful operations to the crash.
Any ideas on what the problem might be?
2021-08-21 03:33:59,336 DEBUG: Undistorting image DJI_0196.JPG
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_visualsfm --points “C:\WebODM\resources\app\apps\NodeODM\data\1c6d4ea4-5c1d-4199-a35c-fd86238abe83\opensfm”
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_openmvs “C:\WebODM\resources\app\apps\NodeODM\data\1c6d4ea4-5c1d-4199-a35c-fd86238abe83\opensfm”
[INFO] Estimating depthmaps
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\OpenMVS\DensifyPointCloud “C:\WebODM\resources\app\apps\NodeODM\data\1c6d4ea4-5c1d-4199-a35c-fd86238abe83\opensfm\undistorted\openmvs\scene.mvs” --resolution-level 1 --min-resolution 2736 --max-resolution 5472 --max-threads 16 --number-views-fuse 2 -w “C:\WebODM\resources\app\apps\NodeODM\data\1c6d4ea4-5c1d-4199-a35c-fd86238abe83\opensfm\undistorted\openmvs\depthmaps” -v 0
Child returned 3221226505
File “C:\WebODM\resources\app\apps\ODM\stages\odm_app.py”, line 89, in execute
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 340, in run
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 321, in run
File “C:\WebODM\resources\app\apps\ODM\stages\openmvs.py”, line 79, in process
system.run(’%s “%s” %s’ % (context.omvs_densify_path,
File “C:\WebODM\resources\app\apps\ODM\opendm\system.py”, line 106, in run
opendm.system.SubprocessException: Child returned 3221226505
Yes, I started again with loading the full set of images. I’m not sure if the problem occurred due to the extra 150 images being on the next day, but the tractor was not moved, and lighting on the tractor was the same- diffused skylight in the shade of trees a few hours before sunset.
I’m on the side of not adding in ignore-gsd until you know something will process. It is oftentimes the cause of many hard to trace issues and failures.
It completed with those settings, so ignore-gsd wasn’t the problem, taking 4h 16m.
Unfortunately the included bits of background texture incorrectly stuck under the tractor canopy are worse now, plus a whole lot of distant background is included, putting the tractor way off centre, and making it very small in the 3D, so not usable.
I removed all the images with significant areas of sky, and used pc-geometric and pc-rectify, but the problem persists.
The point cloud is fine, but textures are being added in the wrong place.
499 images
Options: mesh-octree-depth: 12, mesh-size: 300000, min-num-features: 10000, pc-geometric: true, pc-quality: high, pc-rectify: true, use-3dmesh: true
