Download vegetation indexes
Hi everyone,
I would like to download a selection of the vegetation indexes available after processing with the webodm webpage but it is not possible. Is there any way I can do it? thanks in advance.
Jairo
What version of WebODM are you using?
You should have an option to export the Plant Indices to GeoTiff from the Map View Page, under the Layer options.
Hi Saijin!!
thanks for your reply. I can see and download VI where you mention. But when I am not using lighting, and only use the webpage, I am not able to download the VegIndexes.
Correct, at the moment, the workflow is to download the Vegetation Indices on-demand from the WebODM map view, as they’re not generated as part of the normal processing workflow.
