Hello everyone, I want to download orthophoto of png format but it is not available in WebODM API. There is only orthophoto.tif available. Can someone help me?
Hi @1anhthanh1997
turn on the --orthophoto-png
option from the task options when processing a task.
Is it in the “All Assets” archive?
No. Orthophoto.png isn’t in the “All asserts” archive.
Are you running the latest version of NodeODM/ODM? A copy of the task log would also help.
I updated the lastest version yesterday so I think it’s the lastest version.
Today I also tried to update the lastest version and created a new task but the orthophoto wasn’t available.
Can you provide this?
Could you show me how to get the task log?
This is my task log:
… output truncated at 500 lines …
(pdal info filters.hexbin Error) GDAL failure (1) OGR_G_RemoveGeometry() not supported on polygons yet.
[INFO] running pdal info --summary /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferenced_model.laz > /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferenced_model.summary.json
[INFO] running ogr2ogr -overwrite -f GPKG -a_srs “+proj=utm +zone=17 +datum=WGS84 +units=m +no_defs” /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferenced_model.bounds.gpkg /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferenced_model.bounds.geojson
[INFO] Running georeferencing with OpenSfM transformation matrix
[INFO] running /code/build/bin/odm_georef -bundleFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/opensfm/bundle_r000.out -inputTransformFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/opensfm/geocoords_transformation.txt -inputCoordFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/coords.txt -inputFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_texturing/odm_textured_model.obj -outputFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_texturing/odm_textured_model_geo.obj -logFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferencing_log.txt -outputTransformFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferencing_transform.txt -georefFileOutputPath /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferencing_model_geo.txt
[INFO] Running odm_dem stage
[WARNING] Maximum resolution set to GSD - -300% (25.33 cm / pixel, requested resolution was 5.0 cm / pixel)
[INFO] Classify: False
[INFO] Create DSM: False
[INFO] Create DTM: False
[INFO] DEM input file /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferenced_model.laz found: True
[INFO] Finished odm_dem stage
[WARNING] Maximum resolution set to GSD - 10.0% (5.7 cm / pixel, requested resolution was 5.0 cm / pixel)
[INFO] running /code/build/bin/odm_orthophoto -inputFiles /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_texturing_25d/odm_textured_model_geo.obj -logFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto_log.txt -outputFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto_render.tif -resolution 17.5432457777 -outputCornerFile /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto_corners.txt
[INFO] Creating GeoTIFF
[INFO] running gdal_translate -a_ullr 436847.039171 4572938.53198 437218.250978 4572662.84833 -co NUM_THREADS=2 -co BIGTIFF=IF_SAFER -co BLOCKYSIZE=512 -co COMPRESS=DEFLATE -co BLOCKXSIZE=512 -co TILED=YES -co PREDICTOR=2 -a_srs “+proj=utm +zone=17 +datum=WGS84 +units=m +no_defs +type=crs” --config GDAL_CACHEMAX 40.75% --config GDAL_TIFF_INTERNAL_MASK YES /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto_render.tif /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto.tif > /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/gdal_translate_log.txt
[INFO] Cropping /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto.tif
[INFO] running gdalwarp -cutline /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_georeferencing/odm_georeferenced_model.bounds.gpkg -crop_to_cutline -co NUM_THREADS=2 -co BIGTIFF=IF_SAFER -co BLOCKYSIZE=512 -co COMPRESS=DEFLATE -co BLOCKXSIZE=512 -co TILED=YES -co PREDICTOR=2 -dstalpha /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto.original.tif /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto.tif --config GDAL_CACHEMAX 40.75%
Using band 4 of source image as alpha.
Creating output file that is 6399P x 4513L.
Processing input file /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto.original.tif.
0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] Generating PNG
[INFO] running gdal_translate -of png “/var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto.tif” “/var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8/odm_orthophoto/odm_orthophoto.png” --config GDAL_CACHEMAX 40.75%
Input file size is 6399, 4513
0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] Finished odm_orthophoto stage
[INFO] No more stages to run
[INFO] MMMMMMMMMMMNNNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMNNNMMMMMMMMMMM
[INFO] MMMMMMdo:…—…/sNMMMMMMMMMMMMMMMMMMMMMMMMMMNs/…—…:odMMMMMM
[INFO] MMMMy-.odNMMMMMNy//mMMMMMMMMMMMMMMMMMMMMMMm/
/hNMMMMMNdo.-yMMMM
[INFO] MMN/sMMMMMMMMMNNMm/
yMMMMMMMMMMMMMMMMMMMMy/mMNNMMMMMMMMNs
/MMM
[INFO] MM/ hMMMMMMMMNs.+MMM/ dMMMMMMMMMMMMMMMMMMh +MMM+.sNMMMMMMMMh +MM
[INFO] MN /MMMMMMNo/./mMMMMN :MMMMMMMMMMMMMMMMMM: NMMMMm/./oNMMMMMM: NM
[INFO] Mm +MMMMMN+ /MMMMMMM
-MMMMMMMMMMMMMMMMMM-MMMMMMM:
oNMMMMM+ mM
[INFO] MM…NMMNs./mNMMMMMMMy sMMMMMMMMMMMMMMMMMMo hMMMMMMMNm/.sNMMN-MM [INFO] MMd
:mMNomMMMMMMMMMy:MMMMMMMNmmmmNMMMMMMN:
hMMMMMMMMMdoNMm-dMM [INFO] MMMm:.omMMMMMMMMNh/ sdmmho/.
…-``-/sddh+ /hNMMMMMMMMdo.:mMMM [INFO] MMMMMd+--/osss+:-:/
:- .ym+ hmo``:-` `+:-:ossso/-:+dMMMMM [INFO] MMMMMMMNmhysosydmNMo /ds`/NMM+ hMMd..dh. sMNmdysosyhmNMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMMs .:-:``hmmN+ yNmds -:.:`-NMMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMN.-mNm- //:::. -:://: +mMd`-NMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM+ dMMN -MMNNN+ yNNNMN :MMMs sMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM`.mmmy /mmmmm/ smmmmm``mmmh :MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM``:::- ./////. -:::::` :::: -MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM:`mNNd /NNNNN+ hNNNNN .NNNy +MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMd`/MMM.`ys+//. -/+oso +MMN.`mMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMMy /o:- `oyhd/ shys+ `-:s-`hMMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMNmdhhhdmNMMM` +d+ sMMM+ hMMN:`hh- sMMNmdhhhdmNMMMMMMMM [INFO] MMMMMms:::/++//::+ho .+- /dM+ hNh- +/` -h+:://++/::/smMMMMM [INFO] MMMN+./hmMMMMMMNds- ./oso:.``:. :-``.:os+- -sdNMMMMMMmy:.oNMMM [INFO] MMm-.hMNhNMMMMMMMMNo`/MMMMMNdhyyyyhhdNMMMM+`oNMMMMMMMMNhNMh.-mMM [INFO] MM:`mMMN/-sNNMMMMMMMo yMMMMMMMMMMMMMMMMMMy sMMMMMMMNNs-/NMMm`:MM [INFO] Mm /MMMMMd/.-oMMMMMMN :MMMMMMMMMMMMMMMMMM-`MMMMMMMo-./dMMMMM/ NM [INFO] Mm /MMMMMMm:-`sNMMMMN :MMMMMMMMMMMMMMMMMM-`MMMMMNs`-/NMMMMMM/ NM [INFO] MM:`mMMMMMMMMd/-sMMMo yMMMMMMMMMMMMMMMMMMy sMMMs-/dMMMMMMMMd`:MM [INFO] MMm-.hMMMMMMMMMdhMNo`+MMMMMMMMMMMMMMMMMMMM+`oNMhdMMMMMMMMMh.-mMM [INFO] MMMNo./hmNMMMMMNms--yMMMMMMMMMMMMMMMMMMMMMMy--smNMMMMMNmy/.oNMMM [INFO] MMMMMms:-:/+++/:-+hMMMMMMMMMMMMMMMMMMMMMMMMMNh+-:/+++/:-:smMMMMM [INFO] MMMMMMMMNdhhyhdmMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMmdhyhhmNMMMMMMMM [INFO] MMMMMMMMMMMMMMMNNNNNMMMMMMNNNNNNMMMMMMMMNNMMMMMMMNNMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMh/-...-+dMMMm......:+hMMMMs../MMMMMo..sMMMMMMMMMMMM [INFO] MMMMMMMMMMMM/ /yhy- sMMm -hhy/ :NMM+ oMMMy /MMMMMMMMMMMM [INFO] MMMMMMMMMMMy /MMMMN` NMm /MMMMo +MM: .` yMd
:MMMMMMMMMMMM
[INFO] MMMMMMMMMMM+ sMMMMM: hMm /MMMMd -MM- /s h.
d- -MMMMMMMMMMMM
[INFO] MMMMMMMMMMMs +MMMMM. mMm /MMMMy /MM. +M/ yM: MMMMMMMMMMMM [INFO] MMMMMMMMMMMN- smNm/ +MMm :NNdo
.mMMoMM+/yMM/ MMMMMMMMMMMM [INFO] MMMMMMMMMMMMNo-
:yMMMm :sNMMM
sMMMMMMM+ NMMMMMMMMMMM
[INFO] MMMMMMMMMMMMMMMNmmNMMMMMMMNmmmmNMMMMMMMNNMMMMMMMMMNNMMMMMMMMMMMM
[INFO] OpenDroneMap app finished - Tue Apr 21 16:59:03 2020
Postprocessing: /var/www/data/2721b0ed-29e2-499e-8586-1fddf9de60d8
Generating Base Tiles:
0
20
30
40
50
60
70
80
90
100
Generating Overview Tiles:
0
10
20
30
40
50
60
70
80
90
100
Found point cloud: odm_georeferencing/odm_georeferenced_model.laz
Scanning input
1/1: odm_georeferencing/odm_georeferenced_model.laz
Determined SRS from an input file
Entwine Version: 2.1.0
EPT Version: 1.0.0
Input:
File: odm_georeferencing/odm_georeferenced_model.laz
Total points: 8,710,673
Density estimate (per square unit): 86.1532
Threads: [1, 4]
Output:
Path: entwine_pointcloud/
Data type: laszip
Hierarchy type: json
Sleep count: 2,097,152
Scale: 0.01
Offset: (437033, 4572800, 242)
Metadata:
SRS: EPSG:32617
Bounds: [(436847, 4572663, 217), (437218, 4572937, 268)]
Cube: [(436846, 4572613, 56), (437220, 4572987, 430)]
Storing dimensions: [
X:int32, Y:int32, Z:int32, Intensity:uint16, ReturnNumber:uint8,
NumberOfReturns:uint8, ScanDirectionFlag:uint8,
EdgeOfFlightLine:uint8, Classification:uint8, ScanAngleRank:float,
UserData:uint8, PointSourceId:uint16, GpsTime:double, Red:uint16,
Green:uint16, Blue:uint16, OriginId:uint32
Build parameters:
Span: 128
Resolution 2D: 128 * 128 = 16,384
Resolution 3D: 128 * 128 * 128 = 2,097,152
Maximum node size: 65,536
Minimum node size: 16,384
Cache size: 64
Adding 0 - odm_georeferencing/odm_georeferenced_model.laz
Pushes complete - joining...
Done!
This looks normal.
I think this is due to the reference to odm_orthophoto.png being missing. I’ve opened a patch for this: Add PNG to assets list by pierotofy · Pull Request #854 · OpenDroneMap/WebODM · GitHub
However, the file should be in odm_orthophoto/odm_orthophoto.png
if you download the all.zip
(All Assets) file. Are you sure it’s not there?
I checked it and i found the odm_othophoto.png but i can’t directly download odm_orthophoto.png file like odm_orthophoto.tif.
Very good!
We have a patch coming that will fix that.
I hope to see it soon. Thank you for your help.
