Downgrading WEBODM
Hi!
I’m having troubles in updating webodm via docker. By now I need instructions how to downgrade 1.9.11 to 1.9.7 or older.
I tried to update my webodm and then rebuild using my processor like this post:
In the first test I made i got success, but in this case i got the following error:
[INFO] running “/code/SuperBuild/install/bin/odm_orthophoto” -inputFiles /var/www/data/75b20dc3-fc99-41d5-b5c8-8cdd8f08c990/odm_texturing_25d/odm_textured_model_geo.obj -logFile “/var/www/data/75b20dc3-fc99-41d5-b5c8-8cdd8f08c990/odm_orthophoto/odm_orthophoto_log.txt” -outputFile “/var/www/data/75b20dc3-fc99-41d5-b5c8-8cdd8f08c990/odm_orthophoto/odm_orthophoto_render.tif” -resolution 23.25028777514098 -outputCornerFile “/var/www/data/75b20dc3-fc99-41d5-b5c8-8cdd8f08c990/odm_orthophoto/odm_orthophoto_corners.txt”
/bin/sh: 1: /code/SuperBuild/install/bin/odm_orthophoto: not found
Child returned 127
File “/code/opendm/types.py”, line 346, in run
[Previous line repeated 7 more times]
File “/code/opendm/types.py”, line 327, in run
File “/code/stages/odm_orthophoto.py”, line 71, in process
system.run(’"{odm_ortho_bin}" -inputFiles {models} ’
opendm.system.SubprocessException: Child returned 127
[ERROR] The program exited with a strange error code. Please report it at https://community.opendronemap.org
100 - done.
I also try to rebuild some modules, but without success.
Any ideas? Thanks!
Have you tried upgrading to current v1.9.12? Why must you downgrade?
Because rebuild in last version isnt working and i need it running until i got the problem’s solution.
–Update–
When i try to remake via ./configure.sh reinstall on /code inside nodeodm container i got the following error:
[ 75%] Performing install step for ‘opencv’
[ 0%] Built target opencv_videoio_plugins
[ 0%] Built target ittnotify
[ 1%] Built target quirc
[ 4%] Built target ade
[ 8%] Built target ippiw
[ 8%] Built target gen_opencv_python_source
[ 18%] Built target libprotobuf
[ 31%] Built target IlmImf
[ 44%] Built target opencv_core
[ 44%] Built target opencv_flann
[ 46%] Built target opencv_ml
[ 57%] Built target opencv_imgproc
[ 59%] Built target opencv_photo
[ 62%] Built target opencv_imgcodecs
[ 67%] Built target opencv_features2d
[ 68%] Built target opencv_videoio
[ 81%] Built target opencv_dnn
[ 87%] Built target opencv_calib3d
[ 87%] Built target opencv_highgui
[ 89%] Built target opencv_objdetect
[ 91%] Built target opencv_video
[100%] Built target opencv_gapi
[100%] Built target opencv_python3
Install the project…
– Install configuration: “Release”
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ippicv-readme.htm
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ippicv-EULA.txt
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ippicv-third-party-programs.txt
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ippiw-support.txt
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ippiw-third-party-programs.txt
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ippiw-EULA.txt
– Installing: /code/SuperBuild/install/share/licenses/opencv4/opencl-headers-LICENSE.txt
– Installing: /code/SuperBuild/install/include/opencv4/opencv2/cvconfig.h
– Installing: /code/SuperBuild/install/include/opencv4/opencv2/opencv_modules.hpp
– Installing: /code/SuperBuild/install/lib/cmake/opencv4/OpenCVModules.cmake
– Installing: /code/SuperBuild/install/lib/cmake/opencv4/OpenCVModules-release.cmake
– Installing: /code/SuperBuild/install/lib/cmake/opencv4/OpenCVConfig-version.cmake
– Installing: /code/SuperBuild/install/lib/cmake/opencv4/OpenCVConfig.cmake
– Installing: /code/SuperBuild/install/bin/setup_vars_opencv4.sh
– Installing: /code/SuperBuild/install/share/opencv4/valgrind.supp
– Installing: /code/SuperBuild/install/share/opencv4/valgrind_3rdparty.supp
– Installing: /code/SuperBuild/install/share/licenses/opencv4/openexr-LICENSE
– Installing: /code/SuperBuild/install/share/licenses/opencv4/openexr-AUTHORS.ilmbase
– Installing: /code/SuperBuild/install/share/licenses/opencv4/openexr-AUTHORS.openexr
– Installing: /code/SuperBuild/install/share/licenses/opencv4/protobuf-LICENSE
– Installing: /code/SuperBuild/install/share/licenses/opencv4/protobuf-README.md
– Installing: /code/SuperBuild/install/share/licenses/opencv4/quirc-LICENSE
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ittnotify-LICENSE.BSD
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ittnotify-LICENSE.GPL
– Installing: /code/SuperBuild/install/include/opencv4/opencv2/opencv.hpp
– Installing: /code/SuperBuild/install/share/licenses/opencv4/ade-LICENSE
– Installing: /code/SuperBuild/install/lib/libopencv_core.so.4.5.0
– Set runtime path of “/code/SuperBuild/install/lib/libopencv_core.so.4.5.0” to “/code/SuperBuild/install/lib”
– Installing: /code/SuperBuild/install/include/opencv4/opencv2/core/opencl/ocl_defs.hpp
– Installing: /code/SuperBuild/install/include/opencv4/opencv2/core/opencl/opencl_info.hpp
– Installing: /code/SuperBuild/install/include/opencv4/opencv2/core/opencl/opencl_svm.hpp
– Installing: /code/SuperBuild/install/include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_clamdblas.hpp
– Set runtime path of “/code/SuperBuild/install/lib/python3.9/dist-packages/cv2/python-3.9/cv2.cpython-39-x86_64-linux-gnu.so” to “/code/SuperBuild/install/lib”
– Installing: /code/SuperBuild/install/lib/python3.9/dist-packages/cv2/config-3.9.py
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_eye.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_eye_tree_eyeglasses.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_frontalcatface.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_frontalcatface_extended.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_frontalface_alt.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_frontalface_alt2.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_frontalface_alt_tree.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_frontalface_default.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_fullbody.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_lefteye_2splits.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_licence_plate_rus_16stages.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_lowerbody.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_profileface.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_righteye_2splits.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_russian_plate_number.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_smile.xml
– Installing: /code/SuperBuild/install/share/opencv4/haarcascades/haarcascade_upperbody.xml
– Installing: /code/SuperBuild/install/share/opencv4/lbpcascades/lbpcascade_frontalcatface.xml
– Installing: /code/SuperBuild/install/share/opencv4/lbpcascades/lbpcascade_frontalface.xml
– Installing: /code/SuperBuild/install/share/opencv4/lbpcascades/lbpcascade_frontalface_improved.xml
– Installing: /code/SuperBuild/install/share/opencv4/lbpcascades/lbpcascade_profileface.xml
– Installing: /code/SuperBuild/install/share/opencv4/lbpcascades/lbpcascade_silverware.xml
[ 76%] Completed ‘opencv’
[ 76%] Built target opencv
make: *** [Makefile:103: all] Error 2
I downgrade modifying the files docker-compose.yml and docker-compose.nodeodm.yml putting the version i wanted:
image: opendronemap/webodm_webapp:1.9.2
image: opendronemap/nodeodm:2.4.10
And got the exact same error
Can you use more recent tags than that? That’s quite old.
I’m trying to make the same process using newer versions.
-update-
Same error in all versions:
[ 73%] Completed ‘opencv’
/usr/bin/cmake -E make_directory /code/SuperBuild/build/CMakeFiles
/usr/bin/cmake -E touch /code/SuperBuild/build/CMakeFiles/opencv-complete
/usr/bin/cmake -E touch /code/SuperBuild/build/opencv/stamp/opencv-done
make[2]: Leaving directory ‘/code/SuperBuild/build’
[ 73%] Built target opencv
make[1]: Leaving directory ‘/code/SuperBuild/build’
Apparently Error 2 just means a sub-process failed for some reason… Not terribly helpful for us, unfortunately.
Any idea how to debug this?
I manage to rebuild opencv and got this error on webodm when trying to process my dataset:
ModuleNotFoundError: No module named ‘opensfm’
It looks like OpenSFM must be the module that failed building with the above Error 2. I think?
Since i got the same error above i manually rebuilt all packages and got stuck on this error inside WebODM:
File “/code/run.py”, line 15, in
from opendm.utils import get_processing_results_paths, rm_r
File “/code/opendm/utils.py”, line 3, in
from opendm.photo import find_largest_photo_dim
File “/code/opendm/photo.py”, line 18, in
from opensfm.sensors import sensor_data
File “/code/SuperBuild/install/bin/opensfm/opensfm/sensors.py”, line 3, in
from opensfm import context
File “/code/SuperBuild/install/bin/opensfm/opensfm/context.py”, line 8, in
from loky import get_reusable_executor
File “/usr/local/lib/python3.9/dist-packages/loky/init.py”, line 19, in
from .backend.reduction import set_loky_pickler
File “/usr/local/lib/python3.9/dist-packages/loky/backend/reduction.py”, line 82, in
import cloudpickle # noqa: F401
File “/usr/local/lib/python3.9/dist-packages/cloudpickle/init.py”, line 3, in
from cloudpickle.cloudpickle import *
File “/usr/local/lib/python3.9/dist-packages/cloudpickle/cloudpickle.py”, line 145, in
_cell_set_template_code = _make_cell_set_template_code()
File “/usr/local/lib/python3.9/dist-packages/cloudpickle/cloudpickle.py”, line 126, in _make_cell_set_template_code
return types.CodeType(
TypeError: an integer is required (got type bytes)
