I’m trying to make a rerun to complete a 2D mosaic, Does Rerun use credits ?
If you’re using Lightning to process the dataset, yes!
If you’re processing locally, no.
Sorry for this newbie question but how to process locally ?
OK then, If we install WEBODM locally with the Windows installer
Will it run on a Windows Server 2012 R2 OS ?
Should, provided it is fully patched and up to date, as that should be equivalent to Windows 8.1, which is still supported.
Hi Saijin
Thanks for your swift response, we will then buy credits and a local licence to try WEBODM thoroughly.
