I have noticed that the disk space used on my Docker VM continues to climb even though I always delete the task datasets and output files and start from scratch in most cases.
What is consuming the space and what can I do to either prevent it or to clean it up?
Thanks!
Yeah that’s docker’s typical behavior. A few good tips are here https://lebkowski.name/docker-volumes/
So I have had to tear down and rebuild my VM several times in the past few weeks due to the VM’s disk space being slowly consumed.
I looked at the link referenced above and have been using the docker system prune and docker system prune -a commands and this has not helped much.
The space gets consumed during each task I run in WebODM and even if I delete the task’s files, the space remains used up.
The only way I have found to get the space back is to start over.
