Docker settings
I’ve about 800 photos to process. Can anyone tell me how I do have to set the memory settings in Docker? OS is Windows 10 Pro.
Thanks,
Jan
I’d start with CPUs at 80%, Memory at 80%, swap at 1 GB, and disk image size where it is. If this your first attempt, start with a subset of your photos (try 100 photos which are near one another) and see how it goes. Run again with more photos, repeat a couple of times until you’ve run the whole set.
Thanks Corey, it works well!
