Docker query. Release of assigned resources?
Hi, quicky from a non-tech: does Docker release the assigned hardware resources when closed down?
I accept accurate sarcasm as a valid response!
Sef :slight_smile:
That really depends.
What backend are you using for Docker?
Saijin, I am so sorry, you’re unfortunate enough to be trying to help someone with very little knowledge… what is a backend?
I am running the Mac version of ODM if that helps?
Docker version: v20.10.5
Nah, no worries!
Does help indeed! I assumed you were using the Windows version of Docker, which can optionally use WSL2 as the “engine” behind the scenes, which does do a (mostly good) job of releasing resources under demand.
I believe Docker for Mac does static allocation of resources, so it should release RAM/CPU/GPU upon full close/shutdown, but disk space will remain allocated.
Thank you, that’s the answer I was hoping for :white_check_mark: :white_check_mark: :white_check_mark:
