I am running ODM from Docker on Windows 10 Pro but the job cannot finish and I have tried on several datasets incl. Calittera from the odm data set
Things go well until the Poisson reconstruction.
I have 16 core 3.5GHz AMD Ryzen 9 3950X and 128GB of RAM with NVIDIA GeForce RTX 2080 Ti.
So RAM and speed should not been an issue.
Docker was installed normally as Docker Desktop from their website and then followed the ODM guide at github.com/OpenDroneMap/ODM/wiki/Docker onlu adding project-path as otherwise it could not find the images
This is the docker command
docker run -it --rm -v “$(pwd)/images:/code/images” -v “$(pwd)/odm_orthophoto:/code/odm_orthophoto” -v “$(pwd)/odm_georeferencing:/code/odm_georeferencing” opendronemap/odm --mesh-size 100000 --project-path /
and this is the end of the log (I see no obvious errors above this but who am I so full log here Full log)
Processing view "0075" (with colors)... Processing view "0076" (with colors)... Writing final point set (12809902 points)... Writing PLY file (12809902 verts, with colors, with normals, with confidences, with values, 0 faces)... done. [INFO] running /code/SuperBuild/src/elibs/mve/apps/meshclean/meshclean -t0.6 --no-clean --component-size=0 "/code/mve/mve_dense_point_cloud.ply" "/code/mve/mve_dense_point_cloud.filtered.ply" MVE FSSR Mesh Cleaning (built on Feb 29 2020, 17:26:02) Loading mesh: /code/mve/mve_dense_point_cloud.ply PLY Loader: comment Export generated by libmve Reading PLY: 12809902 verts... done. Removing low-confidence geometry (threshold 0.6)... Deleted 963299 low-confidence vertices. Writing mesh: /code/mve/mve_dense_point_cloud.filtered.ply Writing PLY file (11846603 verts, with colors, with normals, with confidences, with values, 0 faces)... done. [INFO] Finished mve stage [INFO] Running odm_filterpoints stage [INFO] Filtering point cloud (statistical, meanK 16, standard deviation 2.5) [INFO] running /code/build/bin/odm_filterpoints -inputFile /code/mve/mve_dense_point_cloud.ply -outputFile /code/odm_filterpoints/point_cloud.ply -sd 2.5 -meank 16 -sample 0 [INFO] Finished odm_filterpoints stage [INFO] Running odm_meshing stage [INFO] Writing ODM Mesh file in: /code/odm_meshing/odm_mesh.ply [INFO] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /code/odm_filterpoints/point_cloud.ply --out /code/odm_meshing/odm_mesh.dirty.ply --depth 11 --pointWeight 4 --samplesPerNode 1.0 --threads 1 --linearFit [INFO] running /code/build/bin/odm_cleanmesh -inputFile /code/odm_meshing/odm_mesh.dirty.ply -outputFile /code/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 100000 Killed Traceback (most recent call last): File "/code/run.py", line 57, in <module> app.execute() File "/code/stages/odm_app.py", line 92, in execute self.first_stage.run() File "/code/opendm/types.py", line 464, in run self.next_stage.run(outputs) File "/code/opendm/types.py", line 464, in run self.next_stage.run(outputs) File "/code/opendm/types.py", line 464, in run self.next_stage.run(outputs) File "/code/opendm/types.py", line 464, in run self.next_stage.run(outputs) File "/code/opendm/types.py", line 464, in run self.next_stage.run(outputs) File "/code/opendm/types.py", line 464, in run self.next_stage.run(outputs) File "/code/opendm/types.py", line 445, in run self.process(self.args, outputs) File "/code/stages/odm_meshing.py", line 31, in process verbose=self.params.get('verbose')) File "/code/opendm/mesh.py", line 170, in screened_poisson_reconstruction '-decimateMesh {max_vertex} {verbose} '.format(**cleanupArgs)) File "/code/opendm/system.py", line 76, in run raise Exception("Child returned {}".format(retcode)) Exception: Child returned 137
What can the issue be?
