Docker location of logs
I executed the command:
docker exec -it Container ID bash
Then I went to /var/www/data
There is a directory named d90ec6ea-bfcd-421d-9610-011d785aa0b4. I can roughly guess what process is going on but I could not find where the log file.
Where is the logs created in Docker Container?
Does this process work better for you?:
https://docs.opendronemap.org/tutorials/#accessing-logs-on-the-instance
I don’t have opendronemap/odm image when I execute docker ps command. I use webodm and I have automated it through python script.
Is there any way to get the logs?
docker logs suspicious_keldysh
Thank you for the reply. docker logs suspicious_keldysh command does not provide the detailed log which I am asking. Somewhat Saijin_Naib replied was close enough but I did not have opendronemap/odm image.
