Hello, I have got the same issue that Romi-Arg (WebODM keeps processing and the green bar never end) and with the same drone (DJI Phantom 4 Pro) but processing the set of images locally (node-odm-1).
Details:
WebODM on a local computer (CPU: Intel Core i7, 320 GB storage SSD disk and 32 GB of RAM) installed form the command line.
WebODM version: 1.5.0
Operating System: Ubuntu 20.04
After running $ ./webodm.sh update, the following message appear:
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
More information: I have ran three different projects with different options tasks. The first dataset works well (with an orthophoto-resolution = 2 cm/px) but the other two datasets (orthophoto-resolution = 0.19 cm/px) gets stucked!
I just ran: $ docker run hello-word an the following message appear:
Unable to find image ‘hello-word:latest’ locally
docker: Error response from daemon: pull access denied for hello-word, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied.
See ‘docker run --help’
