Docker compose error for webodm with gpu
I am want to see if I can get GPU acceleration in webodm. My docker installation passes the sanity check.
 docker run --rm --gpus all nvidia/cuda:11.0.3-base-ubuntu20.04 nvidia-smi
Thu Jul 21 18:41:18 2022
| NVIDIA-SMI 510.47.03    Driver Version: 510.47.03    CUDA Version: 11.6     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GRID A100X-20C      On   | 00000000:00:06.0 Off |                    0 |
| N/A   N/A    P0    N/A /  N/A |      2MiB / 20480MiB |      0%      Default |
|                               |                      |             Disabled |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
But when I start the docker with --gpu option I am getting this. Any suggestions?
./webodm.sh --gpu start
00:06.0 3D controller: NVIDIA Corporation Device 20b0 (rev a1)
GPU_NVIDIA has been found
Checking for docker...   OK
Checking for docker-compose...   OK
Starting WebODM...
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.gpu.nvidia.yml up --scale node-odm=1
ERROR: The Compose file './docker-compose.nodeodm.gpu.nvidia.yml' is invalid because:
Unsupported config option for services.node-odm: 'deploy'
The last time this happened to me it was because i had tempered with the docker-compose.nodeodm.gpu.nvidia.yml file. Check if the content is the default.
I cloned the repo few minutes ago and didn’t tamper with anything. Everything is as is…
Does the following work?:
./webodm.sh down && ./webodm.sh --gpu start
Nope, same message:
~/WebODM$ ./webodm.sh down && ./webodm.sh --gpu start
Tearing down WebODM...
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml -f docker-compose.nodemicmac.yml down --remove-orphans
WARNING: Network webodm_default not found.
Starting WebODM...
Host: localhost
Port: 8000
SSL: NO
SSL key:
SSL certificate:
Default Nodes: 1
I do it this way:
  1. Run the GPU nodeODM image separately
    E.g. >docker run -dp 3001:3000 --gpus all --name nodeodmgpu opendronemap/nodeodm:gpu
  2. Start the WebODM image “normally”
    E.g. >./webodm.sh start
  3. Manually add the GPU nodeODM processing node via the WebODM GUI
  4. Select that node when configuring the project task
Thanks. This seems to work, thank you!
docker ps
CONTAINER ID   IMAGE                        COMMAND                  CREATED         STATUS                PORTS                                         NAMES
9a0001bfe521   opendronemap/webodm_webapp   "/bin/bash -c 'chmod??"   3 minutes ago   Up 3 minutes          0.0.0.0:8000->8000/tcp, :::8000->8000/tcp     webapp
586bf26f25d0   opendronemap/webodm_webapp   "/bin/bash -c '/webo??"   3 minutes ago   Up 3 minutes                                                        worker
98993ea1b0eb   opendronemap/nodeodm         "/usr/bin/node /var/??"   4 minutes ago   Up 3 minutes          0.0.0.0:49154->3000/tcp, :::49154->3000/tcp   webodm_node-odm_1
b92959a2ddf8   redis                        "docker-entrypoint.s??"   4 minutes ago   Up 3 minutes          6379/tcp                                      broker
ac2726863c47   opendronemap/webodm_db       "docker-entrypoint.s??"   4 minutes ago   Up 3 minutes          0.0.0.0:49153->5432/tcp, :::49153->5432/tcp   db
56443438edb2   opendronemap/nodeodm:gpu     "/usr/bin/node /var/??"   5 minutes ago   Up 5 minutes          0.0.0.0:3001->3000/tcp, :::3001->3000/tcp     nodeodmgpu
61bbae11aeff   guacamole/guacamole          "/opt/guacamole/bin/??"   8 days ago      Up 3 days             0.0.0.0:49528->8080/tcp, :::49528->8080/tcp   guacamole_exo-guac-guacamole_1
4e99ceed0c18   guacamole/guacd-dev          "/bin/sh -c '/usr/lo??"   8 days ago      Up 3 days (healthy)   4822/tcp                                      guacamole_exo-guac-guacd_1
