Greetings-
I spent the 57.00 to get the installer, and love the program, thank you.
However I cannot add users and do not have all of the ADMIN options, as well as no branding above the program with my LOGO. I downloaded and started using the program about a week ago. Webodm 1.9.16.
The Windows version is meant to be used as a single-user client software, not for a server in an Intranet/LAN hosting situation. In light of that, those options are not in the software (similar to not shipping the LAN Sharing Plugins, etc).
The Linux Docker release is most appropriate for that.
You can reach out to [email protected] if you have any concerns about this
Thank you for the reply- so if I would have installed odm via the command line running docker I would have had those options? I just want to make sure I understand, thanks
Yep! And you’d have the share plugin(s) [you’d need to enable them from the Plugin management page] as well as having it broadcast/accept connections.
