Hi! I recently installed WebODM on Windows 10 and Docker Desktop.
Initially, before installing, I set on docker Resources the disk image size to 256GB, but that didn’t reflected on WebODM Diagnostics page.
Then, I increased the disk image size on Docker Resources to 512GB and applied changes and restarted all, but on WebODM Diagnostic I still see the size limited to 58,4GB.
Maybe I am doing something wrong? Is that the right way to increase or set the available disk size? If it’s required to fresh install again, It’s not a problem for me. Thanks in advance!
