I’m looking for disable the Processing node “node-odm-1” for the user
just disable the node-odm-1
If you don’t need the default “node-odm-1” node, simply pass --default-nodes 0
flag when starting WebODM:
./webodm.sh restart --default-nodes 0
found the info here: GitHub - OpenDroneMap/WebODM: User-friendly, commercial-grade software for processing aerial imagery. 🛩
start application without node-odm-1 because when i run the command
I need the user upload their pictures and there could not do the processing !! just upload pictures and validate. thant’s mean the validation done without the processing node
thanks for help plz
What do you mean by validating the images without processing? Do you have any examples or screenshots of what this workflow looks like?
I did it and I disable the processing node , but i like the upload of pictures done without any processing node .
see the image below, I like that the red frame notification cancels and do my validation of only the uploading
thanks
