I forgot how to disable gpu processing in WebODM native.
I have a set of images that fail in dense reconstruction and that feels strange, so I like to try without the gpu.
I’m running a test now with a small set that I know to work.
It seems the test batch works. I think my 64gigs of ram might be to low for 335 times 20mp images.
How much memory is needed for dense reconstruction?
What parameters are you using, and is the reconstruction area very large? Are you passing a boundary or autoboundary if there is sky/background?
I use Ultra on all, full resolution.
The area is maybe 200 * 100 meters.
WebODM showed me code in a gdal stage, I installed the new update now so I hope it will work now
